Old 05-14-2017, 09:14 PM   #1
spike1
Liked 53 Times in 16 Posts
Default Drag Pak complete 8 3/4 rear axle assembly
Complete big pinion 4.86 axle assembly out of 2009 Drag Pak. 33 spline gun drilled axles, lightweight spool, 5/8 studs, strengthened Moser housing, billet yoke and anti-roll control bar. $1000.
spike1 is offline   Reply With Quote
Old 05-16-2017, 10:23 PM   #2
Ddemon
Default Re: Drag Pak complete 8 3/4 rear axle assembly
Does this have the aluminum centre section?
Ddemon is offline   Reply With Quote
Old 05-21-2017, 09:10 PM   #3
spike1
It is not an aluminum case. It is a "489" heavy duty cast iron case. Came out of my 2009 Drag Pak after putting a nine inch in it for SS.
Old 05-22-2017, 01:42 AM   #4
GTX JOHN
Liked 2,490 Times in 700 Posts
Where are you located?
John Irving
741 Stock
741 Super Stock
Old 05-30-2017, 08:03 PM   #5
spike1
In Ohio. John it is out of my Drag Pak, I put a 9 inch Ford in it when I went to SS and a trans brake. Keith Lynch 937-564-7991 if you need more info.
Search this Thread:
Advanced Search
