Old 05-23-2017, 09:16 AM   #14
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: Let's have a discussion about setting records
Originally Posted by Rsmith38 View Post
Took me 3 years to set the IHRA record (bad fuel, Hurricane -only 1 run)
but I finally got it done! You can't do it at divisonals - so only a few chances to set one.
It was the other way around for us. We always set records at the IHRA Pro-Am events, not national events. You'd teardown on Friday, have everything checked, then sealed when it went back together, and set records on Saturday.
You used to get 5 points for setting a record, which you could earn up to 2x per year. Myron Piatek and I used to bounce records back and forth by a few hundredths to get points. (except the one time we found a bad intake gasket during teardown... I tagged the J/CM 1/4-mile record more than intended, even lifting early! LOL)
There were a few championships decided on record points. Eventually they did away with them.
