Liked 972 Times in 309 Posts
Just wondering................anyone try a 6 speed?
Liked 790 Times in 165 Posts
If I had all 4 speed stuff already, I would put it in. The 5 speed will be faster, but I doubt it is worth a tenth, especially in a big motor fast car. When Kevin Helms ran a stick in his Dragpac it was a 5 speed, I questioned him on it and he said he was sure it was faster. Why don't you talk to Kev. I have run both in my g/s camaro and, but the 5 speed was a nash and not as good a piece as the jericho. ran about the same.
Glenn, I don't know if there is a 6 speed that is approved, or a stock one that would stand up to what we do.
Dave Casey 1330 STK |
Liked 275 Times in 76 Posts
No way it's worth a tenth in performance, that's a sales pitch. Your able to tighten up the rpm drop between gears. Depending on the vendor you have more choices on gearing too.
Give G-Force and Liberty a call. Sean
#4 | |
Liked 20 Times in 16 Posts
If it's a Tremec 5spd, you would likely only be using 4 gears anyway. Remove overdrive gears if you can, it's that much less you have to spin up.
Liked 54 Times in 24 Posts
[QUOTE=Dave Casey;536565]If I had all 4 speed stuff already, I would put it in. The 5 speed will be faster, but I doubt it is worth a tenth, especially in a big motor fast car. When Kevin Helms ran a stick in his Dragpac it was a 5 speed, I questioned him on it and he said he was sure it was faster. Why don't you talk to Kev. I have run both in my g/s camaro and, but the 5 speed was a nash and not as good a piece as the jericho. ran about the same.
I am on the fence as to use a Liberty or a G-Force. I'm sure the 5 speed would be faster and probably more fun. But if it's just a small increment faster and a bit more inconsistent to nail dial in, it may not be worth the plus side. That's what I'm looking at. Good Idea about talking to Kevin! I will try to PM him
Todd Gross 3323 FS/E,F |
Liked 1,432 Times in 299 Posts
I would go five speed. You can get a better spread on gear ratios and it would just be more fun! There is no issue of consistency being different between four or five speeds. The five speed is heavier bring a friend when you need to put it in! LOL
James Schaechter 3163 STK Last edited by james schaechter; 06-06-2017 at 08:53 PM. |
I think G-FORCE makes a 6 speed based on the Doug Nash Tranny. A friend on mine has one in his 59 Vette. This is a street trans, but I think they said they could build a race version. Six speeds in our car, you would be busy.
Wow. 6 speed? I don't think my attention span could handle that.
Ask a PRO stock racer how many gears they would use, if they could. The more the merrier!
