Old 06-05-2017, 08:00 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Hardblock?
I have a set of S/S 350ci chevy pistons + .060''....should I hardblock fill my 010 block to support that large an oversize? wondering about the extra weight too...tks.
Old 06-05-2017, 08:34 PM   #2
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Default Re: Hardblock?
Most replies are going to favor the hardblock procedure.
Old 06-05-2017, 09:12 PM   #3
HP HUNTER
Liked 372 Times in 129 Posts
Yes
Old 06-05-2017, 09:17 PM   #4
Liked 1,831 Times in 415 Posts
Absolutely. In fact, you should probably have it thoroughly sonic tested. The majority of those blocks are really marginal at that over size.
Old 06-05-2017, 11:15 PM   #5
richie 2
alan even if its thin, would the filler not still support it? so the thicker the better...fill the thickest one?
Old 06-06-2017, 05:47 AM   #6
carl hinkson
Liked 18 Times in 10 Posts
Sonic test first and at that bore plate honing is a must to achieve good ring seal.
Personally i don't find many OEM blocks that would be a good build at .060 over. Like I said sonic test first.
carl hinkson is offline   Reply With Quote
Old 06-06-2017, 12:06 PM   #7
James L Miller
Liked 25 Times in 16 Posts
Do you use a half fill or a full fill? Do you put a gasket and head on after filling that side of the block so the bores are distorted in the same way as when running? I was thinking of buying the full fill Hard-Blok and then using half in my 273 Mopar block (and 1/2 of that on each side). I've never used this before, but the cylinder walls on the 273 blocks are under .200" thick, some down around .130" with a standard bore. The cylinder walls tend to be thinner in the middle and the front and rear areas between the cylinders.
Mopar 2 Ya!
Old 06-06-2017, 04:22 PM   #8
GTX JOHN
Liked 2,486 Times in 697 Posts
.130 at Std. Bore is rather thin.
Might be worth checking a few more blocks.
If that is on thrust side I personally would not like to us that block.
Suggest filling it to within a inch or 1 1/2 to top of water passage if
I did use it.
John Irving
741 Stock
741 Super Stock
Old 06-07-2017, 10:13 AM   #9
randy wilson
Liked 22 Times in 22 Posts
Do what you want, but I wouldn't hard block anything. Did a 0.060 over 283, and a 0.030 327, and if you could watch the shaking of the stones when rehoning after teardown, versus ones being honed without any hardblock, you'd know what I mean. They never, ever, stayed round. And everything was done with two torqueplates, mains, and pump installed. I have never used it since.
don,t have one
Old 06-07-2017, 11:04 AM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you had the choice , wouldn't it be better to start with a good block , like a Bowtie or Dart ? A filled block has other problems like bores going out of round , or cooling problems when racing . What does a filled block weigh , compared to a Bowtie block . Plus after you where it out for bore size , it can be sold to someone that can use a bigger bore size . In the long run it might not really cost more to run a good block .
