#11 |
Liked 84 Times in 42 Posts
Mike,
What do you use for the comparison base. DA, ALT A, Barometric pressure, ??
Bob Tilton 568 FS/H |
#12 |
Liked 198 Times in 79 Posts
The system that I had asked for Pressure altitude dry bulb temp and wet bulb temp. It would put out a corrected altitude. Then you could ask it for a ET prediction based an a previous run and those three inputs. Was very close usually.
Mike Fuller 396 STK 3961 SS Last edited by Mike Fuller; 06-07-2017 at 08:50 PM. |
#13 |
Liked 10,714 Times in 2,230 Posts
Does anyone have a NOVA weather station for sale?
#14 |
Liked 91 Times in 51 Posts
I use Computech RaceAir handheld. I have 11 No Box/PRO ET championships with it.
My pit partner also uses Computech but it interfaces to Crew Chief Pro. He also has a couple of Championships with it. I like the handheld, as it is mobile, and important if there are long delays while in staging. You choose the best, recent run as your baseline using Correction Factor or DA, and then the current factor to predict your next ET. If your combo is jetted correctly and the AFR is close to optimum (12.7-12.9 in my case), it will run within .005. Jay/Computech answers the phone on the weekends, also. I would also recommend DragStat ($ vs $$$) for your laptop. Created by a NHRA Super class racer (and D5 champ) out of Colorado. He also answers the phone for tech support. Clark Doukas |
#15 |
#16 | |
Sponsor
Liked 63 Times in 11 Posts
We invented and have been manufacturing PerformAIRE weather stations for 25 years. I don't think we would have been doing it this long if our systems were not capable of working correctly. In order for any car to be predictable with any weather system the car must be repeatable and jetted correctly to respond to air change. If your car will NOT run the same 60' (+/0.002) and ET(+/-0.005) on back to back runs in the with the same DA (+/-100DA), it will never be more predictable then its best back to back run. Also very important is the Data you enter. Garbage in Garbage out. Per our instructions: You need to have at least 1000' change in DA across 5 to 6 runs in order to generally get a good prediction. Entering 2 or 3 runs with only a few hundred feet change in DA will generally NOT give a good prediction. We are always happy to take a look at your data and try to help you. You are free to email us directly with the run information you are trying to use, or if you like post it here and I will comment on it. |
#17 | |
Liked 21 Times in 7 Posts
Sorry if this seems like a hijack, but one thing I see quite regularly, and it undoubtedly impacts ET consistency, is engine tuning with wide-band sensors in the header collector, and no turn-down elbows or extensions. More often than not the collector-mounted sensor gives a false reading that shows significantly leaner than the engine is actually running at. If you look at the attached picture, you can clearly see the collector sensor is reading much-much leaner than the sensors in each primary, mounted about 10" from the header flange. For EFI guys, the open collector & free-flowing back pulses are causing the control sensor (in the collector) to chase all over the place while trying to hold the A/F to target. There is absolutely nothing wrong with the EFI system, it is doing what it was commanded to do. In this case the exhaust & sensor locations are the problem, so much so that the EFI AFR Target had to be set to 13.9:1 in order to achieve an actual 12.25:1 ratio. Again, sorry if this seems like a hijack, but I had to chime in because running pig-fat on fuel is likely to cause inconsistencies that a weather station & ET predictor cannot account for. Last edited by Rob Wright; 06-22-2017 at 05:08 PM. |
#18 | |
Liked 237 Times in 126 Posts
DA in the Seattle area can vary from 1963 to 3496 in the same weekend. Happened at the LOD race at Pacific Raceway..
