#1 | |
Liked 18 Times in 10 Posts
Things that should be addressed when having one of those blocks machined. – Main housing bores chamfered – Freeze plug holes and rear cam hole are chamfered – Line honed to at least the middle of the spec or high side if needed – Decked to your demension – Bore to your spec – Plate honed using the same gasket and hardware that will be used in the end build – Lifter bores checked and honed to the lifters that will be used in the end build – Top of lifter bores chamfered – Bottom of the cylinders chamfered – Tap oil galley holes deeper – Chamfer Distributor hole for O rings. |
Liked 346 Times in 126 Posts
that is great advice for chevy people, how about small block mopars?
Liked 25 Times in 16 Posts
Any special preparation needed before HardBlok? Is the standard hot tank good enough, or does it need special rust removal to get a good bond to the iron? I'm thinking muriatic acid inside with a water flush. Maybe follow with Evap-o-rust or is all of that overkill?
Found this online. http://dalhems.com/f/d/808c931833604...str-022005.pdf
Mopar 2 Ya! Last edited by James L Miller; 06-08-2017 at 11:53 PM. Reason: Add link |
Liked 1,830 Times in 415 Posts
The muriatic acid cleaning is an excellent idea. I don't use anything after that except a flood of good clean water.
I bolt a head to the opposite side of the block, and torque the main caps. Then I pour the first side, and immediately install a cylinder head and torque it. I let it set one week. Then remove the head on the other side, pour that side, reinstall the head, and let it set another week.
Alan Roehrich 212A G/S |
Liked 327 Times in 121 Posts
I use Halco Machine Grout in the BB Chryslers and never had any out of round issues. Is the Hardblock the issue or is it because the Chevy blocks are softer and maybe thinner. I'd love to have one of the new aftermarket BB Chrysler blocks avail but at 4K that probably wont happen. I use the 413 industrial blocks for my 63 and they are about .300" before machining but filled a standard 383 block for my Challenger about 3 years ago and haven't machined it yet so I think it's cured by now. How long are the people who had trouble with the Chev's waiting before machining.
