Old 06-12-2017, 02:44 PM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: All 305 Engines Horsepower
Can you provide any details, like Stock or Super Stock, which "last national event" (because it doesn't seem to be Englishtown)?
Old 06-12-2017, 03:20 PM   #2
Timetraveler
Liked 12 Times in 6 Posts
I would like to hear more information. After you go thru tech or declare a class you can not change classes.
Timetraveler is offline   Reply With Quote
Old 06-12-2017, 03:27 PM   #3
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
There SHOULD BE a mandatory, mandatory tare down on ANY car running 1.20 under.
the index.
If found to be in good standing with the rules & specs., then the appropriate HP should be applied for that combo.(Mine shaft conditions ect. applied of course)
If the car is not in spec.
then disregard the run and take it out of the average
DISMISSAL FOR CAR AND DRIVER FOR 1 YEAR no questions.
That would put an end to this for all parties.
WITHOUT at Tare down and full tec. inspection to uphold the integrity of Stock Super Stock racing, what we have here are some super expensive bracket cars.
This is getting crazy!!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 06-12-2017, 04:25 PM   #4
Mark Callanan
Liked 64 Times in 14 Posts
I didn't want to get into this
but I have to support Rod here
He went through tear down a few weeks ago
He set the record and he had the record before that
He has worked very hard to get to the point he is at
Isn't that what this is all about?
This is about performance isn't it?
Now i dont know why he did it
Maybe just because he can
Either way he spent the money and can do as he wants
Me I will keep working to keep up
Thanks Rod for setting the bar higher,,,,
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 06-12-2017, 05:47 PM   #5
Jeremy K
The majority of the damage was done before Rod. I believe the original post is about the F/SA 1985 Camaro.
Jeremy K is offline   Reply With Quote
Old 06-12-2017, 06:18 PM   #6
Crew Chief
Liked 10 Times in 6 Posts
1 1977 F/SA Michael Iacono, Ridge NY, '85 Camaro 10.646 11.85 -1.204
Crew Chief is offline   Reply With Quote
Old 06-12-2017, 06:58 PM   #7
David Lee
Liked 346 Times in 126 Posts
are all 305s going to be hit or just that combo?
Old 06-12-2017, 07:17 PM   #8
Tom Moock
I think all 305 263hp auto Camaro move to 275hp. Change cam go to 262 hp. or buy a Monte Carlo or Malibu wagon same motor 248hp.Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 06-12-2017, 06:58 PM   #9
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Exactly.......read my proposal to NHRA......
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-12-2017, 07:55 PM   #10
rod butcher
Liked 132 Times in 27 Posts
Mark,
Thanks for the kind words.
I wasn't the one to hit the 305/263 combo first, I was content running 1.15 under for class with 120 lbs extra in the trunk as this was a mineshaft race. After another racer hit our combo the first round of class. I was pissed off and took 100 lbs out for the next round of class and ran 1.264 under, thinking that the next trigger was 1.30 under. As many know we have run our car between 7-8 tenths under for the last 4 years to keep the average down. Only at Indy last year or open races have we held it all the way down. What really sucks for me personally is losing the record that I set a few weeks earlier at Atco because of someone wanted to go to the pole in qualifying.
rod butcher is offline   Reply With Quote
