#1 | |
Liked 30 Times in 17 Posts
The finish should be the same across the entire deck surface including between the bores. Here is an Olds block I just finished.
Bill Koustenis |
Liked 2 Times in 2 Posts
Bill,
That is a fantastic finish. Here's the Steve Schmidt finish and the difference in pattern and where the combustion escaped. Pretty terrible. Thanks for sharing. Bryce |
#3 | |
Bill Koustenis |
Liked 348 Times in 152 Posts
Looks like a broach was used, certainly not CBN or grinder.
Phil Molski PMR Performance S/C 1623 |
#5 | |
I was thinking about this a little. Do you have a picture of the entire deck surface in one shot ? Did it look like it was done in two different cuts ?? I have seen some Dart blocks come with a pretty terrible finish from the factory that almost looks like they made two passes with different cutters. I does not matter because I am going to surface it anyway but I wonder if yours is just the factory finish ? Just thinking out loud ![]()
Bill Koustenis |
Liked 544 Times in 213 Posts
Milling machines like a Storm Vulcan 85 B can leave a poor finish if the carbide cutters are not kept sharp and or the speed is too fast.
You hit some weld spots on factory blocks and just general wear causes them to leave a "file finish"after a while. I ran one for years..... I never got to use the CBN cutters and we never had a grinder.... Wheel had to be crated up and sent out or replace your own cutters but that was usually not a good scenario.......all it took was one cutter to be slightly high or low.... I have an old Van Norman rotary broach at home and it's a real dinosoar.....it needs to go to the scrap pile....
#7 | |
Bill Koustenis |
Liked 18 Times in 10 Posts
#9 | |
I do not have an overall pic of the decks but it was definitely just one pattern. No return travel pattern or variance other than how it looked like an angular path as mentioned before. If I recall correctly, the deck height was 9.804. seems like not alot left for a factory cut. I will be running some Fel-pro 1057 (wire ring composite) gaskets for this go-round. Thanks Bryce |
