Liked 312 Times in 175 Posts
The chassis needs a certification at 9.99 or quicker or if the speed is over 135 mph. I once had a NHRA tech guy question the mph record of the class, not my mph.
Liked 239 Times in 114 Posts
You don't need a window net unless your class requires a roll cage , or you have a certified cage and you are running faster than 9.99 secs or 135 mph .
IMO: If you have a cage, you are required to a have a window net. Also per Ihra rules, net must extend forward to within 2" of the farthest back portion of the steering wheel. Can't find NHRA ruling. Check a few cars for that one!
Yeah, I wouldn't have written that without looking it up in the NHRA rulebook . You can check it out in Section 20, page 32 , under "6.3 Window Net" . It might be different for IHRA .
Liked 886 Times in 238 Posts
I put window nets in all then Stock Elim cages I do .
Most do not use them ,as stated they are not being required to use them unless the cage is required to be certed .
Liked 53 Times in 38 Posts
Well I'm safe on the net or cert, I doubt I'll see F or G get in the nines at my age.
