Old 07-22-2017, 10:40 PM   #1
Biscayne
Biscayne's Avatar
Liked 2 Times in 2 Posts
Default 459 Chevy Intake
How much horse power can be made with a 459 intake? On a 327 stroker, possibly a 383. Acid ported and hand ported. What kind of power levels do the 327 300 make with a 459 and AFB in stocker form? Any if would be helpful. Thanks.
Scott Chalk 1226 I/SA
Biscayne is offline   Reply With Quote
Old 07-26-2017, 06:48 PM   #2
Biscayne
Biscayne's Avatar
Default Re: 459 Chevy Intake
350 lookers, but no comments? Or info???
Old 07-26-2017, 10:36 PM   #3
MR DERBY CITY
Liked 8,210 Times in 1,536 Posts
Not as much as an out of the box Edelbrock alum intake manifold.....
Old 07-26-2017, 10:41 PM   #4
Biscayne
Biscayne's Avatar
Obviously, im gonna build an engine for a Factory stock style class. Similar to the FAST series. Has to have factory carb and intake. But you can port heads, increase cubic inches, different cam ,etc. Just wondering what the limits of the 459 intake are?
Old 07-26-2017, 10:54 PM   #5
Scott, Probably not hearing anything because nobody here has first hand knowledge .
There might be one or two 300 hp Stockers out there , but that doesn't help you much with a 383.
All I know is it's worth a bunch over a real 283 intake.
Does the carb have to be stone stock, or NHRA Stock?
Old 07-26-2017, 11:18 PM   #6
MR DERBY CITY
Obviously, I didn't realize you were building an engine for a factory stock style class....sorry......
Old 07-27-2017, 05:18 AM   #7
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Talking Re: 459 Chevy Intake
Acid ported and hand ported in stock ????? Now who would incriminate themselves by admitting this?
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 07-27-2017, 10:08 AM   #8
SDT1DYI
Liked 456 Times in 148 Posts
I would guess an average 350 stocker engine with a 750 Q-jet with that manifold you asked about is in the 415-425 HP range. A really good motor is in the 430-440. The 459 as all the stock SBC manifolds due, fall off in the higher RPM ranges. Important the cam works with the manifold. (Acid dipped or not.)
SDT1DYI is offline   Reply With Quote
Old 07-28-2017, 08:52 AM   #9
Biscayne
Biscayne's Avatar
This is not for a stocker. I was saying that the class I'm gonna run that the intake can be modified.
Old 07-28-2017, 08:55 AM   #10
Biscayne
Biscayne's Avatar
Mark, thanks. It can be an NHRA Stock carb. I was gonna try to run a 409 400 hp AFB carb as it's bigger then the 327 carb
