Old 08-02-2017, 07:45 PM   #331
Billy Nees
Default Re: Important if you run D-H/S or SA
Originally Posted by David Lee View Post
Todd, All I want is an even playing field across the board. Nothing more
So just what is it about your 318 combo that you feel isn't fair?
Billy Nees 1188 STK, SS
Old 08-02-2017, 07:54 PM   #332
David Lee
Liked 346 Times in 126 Posts
I never said there was anything unfair about my combo, but there are combos who can't find any replacement blocks such as you
Old 08-02-2017, 07:59 PM   #333
Hacksaw
Liked 312 Times in 175 Posts
If someone building a combo is so concerned about the lack of availability of an aftermarket block, then he should build a different combo and buy the block of choice. I always say, the planning is the hardest part.
Old 08-02-2017, 08:02 PM   #334
David Lee
Really, you are willing to eliminate that many combos.
Old 08-02-2017, 08:03 PM   #335
Billy Nees
But I'm not complaining about not having a replacement block. I'm complaining about combos that are being given aluminum aftermarket intake manifolds in Stock!
Old 08-02-2017, 08:05 PM   #336
Billy Nees
David, you apparently don't know many hardcore Stock Eliminator racers.
Old 08-02-2017, 08:20 PM   #337
SSDiv6
So wall thickness and deck thickness have nothing to do with a better seal. And if so many racers are going fast, with stock blocks, why the need for aftermarket blocks.
And you want to limit it to that one subject.
Like I said in the previous post, that is the reason why people fill their blocks.
Others sleeve them.
A properly filled or sleeved block, machined with the right equipment and by someone that knows what they are doing, will make power.
Old 08-02-2017, 08:47 PM   #338
Sam Capizzi Jr
Liked 43 Times in 9 Posts
I would be concerned if that 68-71 318 piston with valve reliefs is legal or not. That's a **** load of HP right there that no aftermarket block or head will make up for. Just my 2 cents.
Sam Capizzi Jr. 1301
SS/AS 93 Dodge Daytona
R/SA 73 Dodge Dart
Sam Capizzi Jr is offline   Reply With Quote
Old 08-02-2017, 09:28 PM   #339
James Perrone
Liked 1,842 Times in 429 Posts
So you are against all aftermarket heads too?
I'm all for aftermarket heads. If Everyone Can Have Them!
Main benefit of a aftermarket block is take the hone better last longer but is heaver
You have aftermarket block and sleved it? Really
Reinventing the wheel ?
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 08-02-2017, 09:40 PM   #340
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I am building a 67/68 cuda right now and to answer your question I bought two 340 dealer replacement blocks and have them sleeved down to a 318 bore. I plan on doing my own short block and have shane studley do my heads.
And I have heard that aftermarket blocks get a hell a lot more hp than 5.
David, it would be a good idea to fill them also. A stock 340 typically has about a .100" thick wall and if you run it as a .060" 318, you'll have approx .135" which won't break but it won't make great power either. A lot of aftermarket blocks have about .300" walls.
