Liked 346 Times in 126 Posts
wow, did you actually read what i typed or did you just react?
Liked 312 Times in 175 Posts
This thread is killing me. I don't know if I should start to build a Mopar Stocker or pack drag racing in all together.
Liked 574 Times in 212 Posts
It is killing me too. If Steve Wann has something to do with it, you know it is wicked fast. Ie: A/SA record. The Duster used to be Stevè's car.
Gary Hansen - SS/FA 4911, B/SA 4911 Last edited by SStockDart; 08-05-2017 at 03:26 AM. |
Liked 62 Times in 17 Posts
Liked 21 Times in 8 Posts
if you bolted a stock cast iron intake on that duster it would run exactly the same as the ld 340 . we tried all of that crap 20 plus years ago you would be surprised how little change intake have , they don't turn enough rpm to make a difference. maybe just maybe they spent the time to make the carburetor and fuel system converter gearing shift points etc..... work properly , only benefit I see is 20# in the trunk.
#6 | |
Liked 279 Times in 68 Posts
Greg Hill 4171 STK |
Liked 26 Times in 11 Posts
I've followed this thread for a little while, and I am not that smart, so help me out here.
Someone lobbied NHRA to allow an aftermarket intake manifold in stock eliminator. Correct? Yet this manifold has ZERO performance benefit? See you at the races, Wayne Kerr |
#8 | |
Liked 68 Times in 41 Posts
x2 BTW The track where the d/sa record was set is a very very fast track.I was the next car down the track and was -1 plus under.He did everything right including,the combo, the day,the track, the weather and traction was the best I've seen any where. you should be happy for them.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
