Liked 99 Times in 60 Posts
Consider this thought,
In ref to bushed lifters vs needle bearing lifters, driveshafts have needle bearings in the u-joints.
Larry Woodfin 471W |
#2 | |
Liked 18 Times in 10 Posts
Most of my builds I have been using the Morel .904 lifters with needles in about everything and to date not one problem. |
Liked 312 Times in 175 Posts
Guys like Carl and other engine builders would obviously see the results and the pros and cons of each type. I am no expert, IMO the needle type is more efficient than a bushed lifter. What causes a roller on a needle bearing lifter to stop turning and goon the cam etc. ? I think if the engine gets a flash of rpm, like wacking the throttle in the water, the spring slams the lifter on the cam and it puts a flat spot on a needle and that leads to a failure.
I have run needle bearings (Isky Red Zone) for a few years now, with zero problems, as long as I send them back for a "rebuild" every winter. They won't go two seasons. Mine seldom sees over 8300, with 1015 lbs Open spring pressure.
Your results may vary. LOL
Ed Wright 4156 SS/JA |
I have had more problems with ISKY roller lifters only as far as sizing, Never been able to buy just one set always 2 sets and one build took 3 sets to get the sizing correct.
Liked 1,945 Times in 586 Posts
What valve springs are you using?
Mike Pearson 2485 SS |
I have not had that problem.
1356 pac.
Why does it keep changing caps to lower case??
Ed Wright 4156 SS/JA Last edited by Ed Wright; 08-07-2017 at 08:02 PM. |
Thanks Ed
