Liked 312 Times in 175 Posts
The real beauty of that 1.5" spring is that the pocket in the head is smaller, helps you stay away from water.
Liked 1,945 Times in 586 Posts
Yup that's why we did it. The 441 chevy head is thin in that area.
Mike Pearson 2485 SS |
Back on op: Any other theories on needle bearing lifter failures?
Liked 1,604 Times in 583 Posts
Liked 239 Times in 114 Posts
Prep is important . The assembly grease that holds the needles in place during assembly , needs to be removed before they are run . I use clean mineral spirits and blow dry . It is important not to allow the rollers to spin when blow drying . I have seen some Technicians spin those parts up to untold rpm while trying to dry them . That is a good way to skid and fail the rollers . After drying , I soak the lifters in clean break-in oil , and spin the wheels by hand to try and drive the oil into the rollers . Seems to work , haven't had a failure yet !
#6 | |
Liked 18 Times in 10 Posts
I seen where they have seized in the bore because not enough clearance. Like I have posted before i have pretty much have gone to all .904 roller lifters in most of my builds and alot of the blocks I prep are machined for .904 and no problems. No blocks go out the door with out having lifters in hand and lifter bores are honed to fit the lifters. Had a guy last week where I priced out a Dart Little-M block roller cam bearings, Dry sump ETC. had Comp lifters told him those are to small and would probably need to bush the bores back to standard. He told me they measured .842 my reply was never seen a set of Comp lifters to OEM size yet. He would not send the lifters so I passed on the job and he was pissed at me. https://www.facebook.com/cncblocks.n...79?pnref=story Here is a good video on different lifters and bore clearance Last edited by carl hinkson; 08-08-2017 at 09:14 PM. |
