Old 08-27-2017, 11:54 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Overbore and intake valve size
'79 AMC 304/2 125/180- is there any advantage to boring .060 with a small(1.79) intake and 2BBL carb or will a .030 overbore be sufficient??
House of Darts is offline   Reply With Quote
Old 08-28-2017, 12:09 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Overbore and intake valve size
Well,
Just looking at an engine as an air pump.....
With a +.030 overbore the displacement is 308 ci
With a +.060 overbore the displacement is 314 ci
With a +.080 overbore the displacement is 318 ci
If you make 1 hp/ci you would gain 6 hp going to +.060 plus the additional compression.....
Just my thoughts,
PS:
Don't forget to stroke the crankshaft for additional displacement and compression
With a +.060 bore and a .013 stroke you end up with 315 ci
Bob Mulry 7516 STK
A & M Motorsports
Old 08-28-2017, 01:37 PM   #3
junior barns
Liked 20 Times in 14 Posts
Is there any affect of over boring if the intake cant flow any more air?
junior barns is offline   Reply With Quote
Old 08-28-2017, 02:56 PM   #4
Bob Mulry
Bob Mulry's Avatar
Most likely.....
But shouldn't you build your combination around what you run and more cubic inches can't be a bad thing???????
Bob Mulry 7516 STK
A & M Motorsports
Old 08-28-2017, 03:11 PM   #5
junior barns
yes most definitely,it was just a thought. If you went from 030 to 060 and car slowed down with no other changes could intake actually slow it down in this case?
Old 08-28-2017, 03:23 PM   #6
SSDiv6
In addition to more cubic inches, it will unshroud the valves and chamber which it is a plus for engine flow.
Old 08-28-2017, 08:22 PM   #7
House of Darts
Thinking out loud....the extra weight of the piston is of any concern? The cylinder fills to capacity regardless of any restrictions(valve size, head design)?
Old 08-28-2017, 10:00 PM   #8
Liked 5,147 Times in 1,964 Posts
The piston has a spec weight, regardless of over- bore size.
Everything helps on a small motor, but make sure you concentrate on minimizing the deck height.
Old 09-03-2017, 06:16 PM   #9
jmantle
Liked 172 Times in 81 Posts
If you are having pistons made, first make sure you can get rings for the bore size you pick. Any bore size up to .080 over is legal even if its metric.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
