Old 08-28-2017, 02:28 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Re: mopar master cylinder question
Found what I needed
Thanks
Dave
Last edited by David Lee; 08-28-2017 at 04:12 PM. Reason: no longer needed question
Old 08-31-2017, 08:05 PM   #2
Eman
Liked 133 Times in 76 Posts
Good deal! Just keep in mind the Mopar replacement MC doesn't have any rod retention and the rod fits very shallow into the piston. I removed my brake quadrant and welded in a rod guide, made from a steel plate with a hole in it. It prevents any possibility of the rod falling out of the back of the MC. Also have a positive pedal stop at the top of travel. If your foot hooked the pedal and pulled it up or the piston didn't return as fast as the pedal you don't want the rod falling out.
local racer had it happen and went off the end of the track recently.
Old 09-01-2017, 12:25 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I used one of these for the Camaro... https://www.jerrybickel.com/brake-ki...-jbrc1064.html
Rich Taylor
I/SA - 321
Old 09-01-2017, 09:21 AM   #4
Eman
That works and is bolt in instead of fabricating.
Old 09-01-2017, 03:11 AM   #5
David Lee
I think that happened to ken etter too
Old 09-01-2017, 03:30 PM   #6
David Lee
would you mind if possible of taking a photo of your modification?
Thanks
David
Old 09-03-2017, 05:08 PM   #7
Jeff Stout
Liked 708 Times in 285 Posts
I forgot that I have a used MC from a Wildwood kit I bought. I already had a new 1 installed in car. It came off a working setup is all I know and would sell cheap if interested. $30? plus shipping
Old 09-03-2017, 05:31 PM   #8
David Lee
can you zap a photo?
Old 09-03-2017, 06:11 PM   #9
Jeff Stout
Can you text me at 602-768-3583. I can send pics that way as it is easier. If not ill put them on here. Jeff
Old 09-03-2017, 10:18 PM   #10
Eman
Thanks
David
http://www.maliburacing.com/manualbr...ssy_bottom.jpg
Mine is just like this.
