Old 09-03-2017, 08:54 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default crankshaft bolt on damper turning tool
I have seen this tool but have not found it for sale. Who sells the SBC three bolt flange tool with large hex that is an engine turning tool?
Larry Woodfin 471W
Old 09-03-2017, 09:14 AM   #2
bigfoot584
Default Re: crankshaft bolt on damper turning tool
Summitracing shows one.
Proform Engine Rotation Adapters 66782
bigfoot584 is offline   Reply With Quote
Old 09-03-2017, 09:34 AM   #3
Dragsinger
that is it, Thank you, I knew I had seen it but needed your help
Larry Woodfin 471W
Old 09-03-2017, 03:00 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Looks good. Is this installed temporarily or left on all the time? My balancer bolt has a 1/2 inch fitting in the center but it's hard to get a wrench in there with the pulley and radiator on.
Dale Shearon
68 Mustang 6394
Old 09-03-2017, 03:08 PM   #5
SSDiv6
Temporary installation or use.
Old 09-03-2017, 08:44 PM   #6
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I already have one, but it is a pita to unbolt the pulley to use it. Thinking about using three long studs for the pulley so I can simply slide it on without loosening anything. Weary of banging on the starter to adjust valves.
Rich Taylor
I/SA - 321
Old 09-03-2017, 10:24 PM   #7
Ed Wright
Ed Wright's Avatar
I just run the bolt in the end of my crank in with my 1/2" drive impact wrench. I have a long handle 1/2" drive swivel head ratchet to turn it. It's the same length as a 1/2" drive breakover. I can turn mine backwards without the bolt coming loose.
What is wrong with bumping the starter to set the valves? Been doing it over 40 years with no issues. I have a button next to my hood latch plate for that.
Ed Wright 4156 SS/JA
Old 09-04-2017, 09:04 AM   #8
pmrphil
Liked 348 Times in 152 Posts
Look at the ARP bolts - they have some with either 12 point long heads, and some that have a 1/2" square drive hole inside, along with a big hex outside.
Phil Molski
PMR Performance
S/C 1623
Old 09-04-2017, 09:43 AM   #9
Dragsinger
With my specific need, while on the dyno, no pulleys are installed and the flex plate is inaccessible because of the dyno mounting.
Because of the heavy valve spring load, I do not like the "feel" of the 7/16 center bolt. The above tool will work perfectly in this situation.
This dyno does not allow the engine mounted starter to fit, it has it's own starter and does not "bump" with the control as well as the engine mounted one.
The above tool will let me utilize the above said long ratchet.
And as stated above, in my experience, "bumping" the engine mounted starter is completely acceptable.
Larry Woodfin 471W
Old 09-04-2017, 12:10 PM   #10
HandOverFist
:"Bumping" the starter will work, but you can't really control where it will stop. I prefer to do it manually.
Rich Taylor
I/SA - 321
