Old 09-01-2017, 11:56 AM   #411
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Important if you run D-H/S or SA
Originally Posted by junior barns View Post
Yea! And how fast will Mr. Beach going to go when he does change!!
He's already changed!
Greg Hill 4171 STK
Old 09-01-2017, 12:09 PM   #412
Bruce Noland
Liked 444 Times in 145 Posts
My vote for most impressive performance gain is Mitch in his Barracuda. Not sure if he runs the 340 with the intake in question. 1.16 under at Indy is very impressive.
Bruce Noland 1788 STK
Old 09-01-2017, 12:12 PM   #413
junior barns
Liked 20 Times in 14 Posts
[QUOTE=Greg Hill;543675]He's already changed![/QUOTE
lol If thats the case, from the HP #'s gained from this that i've been hearing, he probably would be very competitive in your class right now!
junior barns is offline   Reply With Quote
Old 09-01-2017, 12:37 PM   #414
Rod Greene
Liked 242 Times in 81 Posts
It is a 383 rated at less HP than a 340.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is online now   Reply With Quote
Old 09-04-2017, 12:35 PM   #415
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
https://www.google.com/amp/www.hotro...flow-test/amp/ The testing in this article shows a lot better flow than the iron intake.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 09-04-2017, 01:02 PM   #416
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
It also shows the Edelbrock RPM averages 45 CFM less than the LD340 but says it makes more power.
Paul Precht is online now   Reply With Quote
Old 09-04-2017, 03:04 PM   #417
SSDiv6
It made more power after it was ported.
Old 09-05-2017, 02:52 AM   #418
john kunsak
The 396/375 68-69 camaro&chevelle with aluminum heads casting# 3919842. Rpo L89 also used on 68 L-88 & 69 corvette L-89. This is a rectangular port ,closed chamber head. It has been discontinued since approx 1985 & superceded by#19331427 in the early 90's. This was a factory assembled combination showroom available.
john kunsak is offline   Reply With Quote
