Liked 99 Times in 60 Posts
Robbie, I think it is a good idea and provides consistent voltage. If you charge the battery as time allows the alternator load is small. In addition, use pulleys that limit the alternator speed to no more than about 20% overdrive.
Larry Woodfin 471W |
Makes more difference with an EFI car. Voltage level effects how fast the injectors open. I found when my 12 volt batteries were a little low, my logger showed it running leaner. That, of course, effects consistency. I had a button under the accelerator pedal, hooked to a relay, that shut the alternator off @ WOT.
Going to two 16 volt batteries cured all that. With no alternator. Had to lean it down with 16 volts batteries. The injectors opened faster, of course.
Ed Wright 4156 SS/JA |
