Old 09-19-2017, 03:21 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
Default Re: Running an alternator
I have never run an alternator. I also have a 16 v battery. I have a lithium battery. They are more stable with the voltage over the charging state. The race car does not run enough to charge the battery with the alternator so I don't see any reason to run one. You still have to charge the batteries between rounds so there is no advantage
Mike Pearson 2485 SS
Old 09-19-2017, 03:42 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
My kid runs 12 volt stuff, bracket car, lights, dial boards, ect. He runs an alternator and very rarely charges his battery, lots of times double entering the car. So from my perspective I'd say they do a fair job of keeping up with the demand. Car prints tickets so I'd say an alternator does not cause inconsistent E.T.'s. Merely my observations.
Joe Buchanan SS/BX 3117
Old 09-19-2017, 03:42 PM   #3
terry1
Liked 24 Times in 13 Posts
Don't you have to run an alternator in Stk?
terry1 is offline   Reply With Quote
Old 09-19-2017, 03:48 PM   #4
Rsmith38
Liked 28 Times in 15 Posts
By NHRA Rules - you need an alternator in Stock -
Rsmith38 is offline   Reply With Quote
Old 09-19-2017, 05:46 PM   #5
Liked 5,147 Times in 1,964 Posts
Wink Re: Running an alternator
Yes, it has to be in place, and turning with the engine ;-)
Old 09-19-2017, 05:55 PM   #6
I've used Ed's idea with the micro switch. I also use it to un-ground the fan relay on the run. Not so much as a speed secret, but to keep the voltage consistent during the run.
Does it help? Can't say, but it can't hurt, as long as you charge between rounds.
We are talking about carb'ed combos here.
Old 09-19-2017, 07:52 PM   #7
Coleydog
Liked 53 Times in 38 Posts
Back in the day we ran a alternator, under driven, charged up for Friday nite then ran Sat and Sunday, had no battery charger at track, 12 volt system. Never a problem starting or running. Let the fan motor run awhile, spray it down, set around waiting with no hassles for the next round, everyone else like ants on candy. Same procedure I'll use on the new car.
Might add, main purpose was to keep 13 volts to run the components not to keep battery charged, alt ran everything, not the bat. Bat just for starting.
Old 10-02-2017, 04:29 PM   #8
MR DERBY CITY
Liked 8,206 Times in 1,536 Posts
Ed, my experience is limited to STOCK Eliminator with ONE 12 volt battery....I will HOT LAP with the best of them because......my charging system is top notch ....Remember , when you are hot lapping there is no time to visit the trailer and charge the battery....
Old 10-02-2017, 08:51 PM   #9
Ed Wright
Ed Wright's Avatar
I know what hot lapping is. Been doing this for about 50 years now. Mine is faster on 16 volts. I also test.
Ed Wright 4156 SS/JA
Old 10-02-2017, 08:57 PM   #10
MR DERBY CITY
So....this should be your GOLDEN anniversary season,....Damn ...your old....LOL.......
