Old 11-09-2017, 12:45 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Re: 318 poly
Finding a cam for one would be a nightmare, but they are solids and adj rockers. Read of a builup on one of these engines, a little head work, cam and good intake, made over 500 hp. Briggs and Stratton valves in them.
Old 11-09-2017, 03:33 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The 62 4 barrel would be great if it were rated around 220. Other than the lifter layout for the canted valves, the shortblock is no different than an LA 318 or 340, it uses the same AFB as the 361/305 with 1.84/1.56 valves and these engines can be had for free although the mani is usually few hundred. Find a clean 62 Dodge or Plymouth 2 or 4 dr and have fun.
Paul Precht is online now   Reply With Quote
Old 11-09-2017, 10:19 PM   #3
House of Darts
Liked 20 Times in 15 Posts
I was thinking of the 2 bbl combo in a A body. Well tuned that combo produces a strong torque curve. With a B&B motor and a stocker cam???? How easy to convince NHRA for a 318 LA rating?
House of Darts is offline   Reply With Quote
Old 11-09-2017, 11:28 PM   #4
Paul Precht
They were never made as far as I know, the A's got the 273.
Old 11-09-2017, 11:52 PM   #5
GTX JOHN
No A body poly 318 every produced.
John Irving
741 Stock
741 Super Stock
Old 11-10-2017, 11:46 AM   #6
novassdude
Liked 136 Times in 49 Posts
This is the new era of NHRA that doesn't matter just send a letter and have it added anyway.
novassdude is offline   Reply With Quote
Old 11-17-2017, 10:24 AM   #7
njk53
A bodies never got the 318 poly, just the B bodies and trucks.
As far as I know, Schneider Cams will grind you any spec. poly cam you want. They will regrind your cam and I think they still have cam blanks.
The bottom end of the poly motor is the same as the LA motor. Crank, rods, etc. are all the same.
Nelson Kowal
Stock 345
Old 11-09-2017, 11:59 PM   #8
GTX JOHN
1962 318 4 bl at 260 the way I read class guide.
John Irving
741 Stock
741 Super Stock
Old 11-10-2017, 01:17 AM   #9
Paul Wong
Liked 419 Times in 85 Posts
A 62 dart is a B Body
Paul Wong is offline   Reply With Quote
Old 11-10-2017, 11:14 AM   #10
GTX JOHN
I know that (I raced a 62 Dart Wagon in G/SA).........I was trying to highlight was that the 260 HP of poly way too high compared to 318 Thermoquad
at 230 HP with way superior CFM carb!!!
See my post #10
John Irving
741 Stock
741 Super Stock
