Old 11-14-2017, 09:18 PM   #1
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: Radiator
I will ask our divisional tech first before ordering. Thanks everyone.
SDT1DYI is offline   Reply With Quote
Old 11-15-2017, 01:36 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Aluminum in the El Camino with zero questions thus far. Painted black one probably could not tell from factory.
Rich Taylor
I/SA - 321
Old 01-27-2019, 02:42 PM   #3
ken robinson
Liked 219 Times in 87 Posts
Why dose the Be-cool radiator cost more than the champion radiator are they that much better ? Which radiator did some of try and why ?
Old 01-27-2019, 05:06 PM   #4
J&S Racing
Liked 319 Times in 82 Posts
I went with the champion for my build... super nice radiator and they were great to work with, I had them replace the ends with AN fittings. They also have a nice shroud.
Old 01-27-2019, 08:19 PM   #5
Brett Albert
Ken,
I ended up going with an aluminum radiator from DeWitts for my 71 Nova. I ordered it painted black. They make a nice product and it fit well with my factory hardware.
Brett Albert
Stock 1459
Brett Albert is offline   Reply With Quote
Old 01-29-2019, 02:14 PM   #6
engineguy
According to NHRA Rulebook, Stock classes:
"Full size radiator mandatory for body used. Aluminum radiators permitted; must retain stock dimensions and appearance. Cutting, denting or elimination of any body, fender, radiator or grille panels prohibited."
Basically, this means that a top/bottom tank (vertical flow) radiator cannot be replaced with a cross-flow radiator and the hose inlet/outlet located must be in the original configuration. Most cars were available with heavy duty radiators, which typically had additional rows of tubes, therefore I don't think that there is any restriction on the thickness of the radiator core used.
engineguy is offline   Reply With Quote
Old 01-29-2019, 04:00 PM   #7
ken robinson
Main thing it's not a round track or street car so you dont need the 3or 4 row core , so a 2 row should work wright . The cost is very different between different makes so is it a quality thing or paying for the name ?
Old 01-29-2019, 06:42 PM   #8
Mike Jones
Liked 684 Times in 289 Posts
Boy does that look nice, Rich...
MJ
