Liked 33 Times in 16 Posts
Aluminum in the El Camino with zero questions thus far. Painted black one probably could not tell from factory.
Rich Taylor I/SA - 321 |
Liked 213 Times in 85 Posts
Why dose the Be-cool radiator cost more than the champion radiator are they that much better ? Which radiator did some of try and why ?
Liked 319 Times in 82 Posts
I went with the champion for my build... super nice radiator and they were great to work with, I had them replace the ends with AN fittings. They also have a nice shroud.
Ken,
I ended up going with an aluminum radiator from DeWitts for my 71 Nova. I ordered it painted black. They make a nice product and it fit well with my factory hardware. Brett Albert Stock 1459 |
According to NHRA Rulebook, Stock classes:
"Full size radiator mandatory for body used. Aluminum radiators permitted; must retain stock dimensions and appearance. Cutting, denting or elimination of any body, fender, radiator or grille panels prohibited." Basically, this means that a top/bottom tank (vertical flow) radiator cannot be replaced with a cross-flow radiator and the hose inlet/outlet located must be in the original configuration. Most cars were available with heavy duty radiators, which typically had additional rows of tubes, therefore I don't think that there is any restriction on the thickness of the radiator core used. |
Main thing it's not a round track or street car so you dont need the 3or 4 row core , so a 2 row should work wright . The cost is very different between different makes so is it a quality thing or paying for the name ?
Ken, check out Spectra Radiator. I used one on my car, direct factory aluminum replacement and very reasonable, and good fit. I believe any NAPA can get them. Also, keep in mind most aluminum radiators I have seen have 1 inch cores vs 3/4 inch cores like most factory radiators.
https://ecat.spectrapremium.com/products/CU337 Hope this helps.
Joe Martens AA/Stock 3969 Last edited by Joe Martens; 01-29-2019 at 04:39 PM. |
Liked 684 Times in 289 Posts
