Old 11-16-2017, 09:58 AM   #21
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Bellhousing
This is from a thread on the YB.
Sent: Saturday, January 07, 2017 11:15 AM
To: Info
Subject: Bellhousing Recertification
Dear Sir
Could you please tell me if an adjustment hole like this is an acceptable modification for recertification?
Thank You
Thank You for your support of McLeod Racing.
Yes that would be acceptable for SFI re certification.
Kind Regards,
cid:448235323@06022013-176A
Billy Mieczkowski
Technical Sales
Mcleod Racing
1600 Sierra Madre Circle
Placentia, Ca 92870
billym@mcleodracing.com
tel:714 630 2764 Ext 223
fax:714 630 5129
Chevy55 is offline   Reply With Quote
Old 11-16-2017, 02:07 PM   #22
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I drilled a hole to check airgap in my Browell. When it came back from the first recert, they tapped it and put a plug in. No questions or additional charges other than the recert fee. Not everyone is liable to do the same, so beware.The bellhousings with a window require recert every 2 years.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 11-16-2017, 03:06 PM   #23
JohnRoderick
JohnRoderick's Avatar
Liked 11 Times in 4 Posts
The SFI re-certification and drilling a hole for the air gap can be an issue. Browell Bellhousing made this modification to mine. As I understand it after having a conversion with Brian at Browell, the only hole that can be drilled into the Bellhousing without impacting the cert has to be done to the transmission flange. People drill a hole in the flange to make clutch adjustments with a T-handle. The large window might not make that necessary. It will depend on the clutch that you use and if you can get access though the window.
https://www.flickr.com/gp/141020629@N07/prnT0P
In regards to the Bickle clutch fork setup. I also attempted to do this.
https://www.flickr.com/gp/141020629@N07/D9R7Kt
I found in theory it works great. However, In practice I found out that the heim joint has too large of a profile and it created clearance issues with the clutch that i am using and the limited space available in the bellhousing. I could not reduce the height of the pivot enough to get enough clearance. The standard pivot ball is a much lower profile. In the end, I used the stock style setup but i reinforced the clutch fork. The Bickle setup is sitting in a drawer.
Originally Posted by J&S Racing View Post
They advertise 13.5lbs. I tossed it on my crappy bathroom scale and it's close.
It's definitely a nice piece and I'll cover the install in my build thread.
Probably not the smartest idea to build a A/B stick car when I have limited knowledge about clutches but we have a few people to help sort me out.
After reading this tread it got my mind going. I thought the point of the window was for adjustments and setting air gap but with guys saying they still had to drill a hole got me thinking......... are you guys really drilling these holes and voiding getting it re certified or is there another way to set the gap??
Oh, another thing speaking of clutch forks......I didn't even think to ask Brian what the offered but from what I see online they only offer a factory style fork. I did some searching and came across a set up from Bickle that does away with the pivot ball and uses a heim joint. Would this be legal?
JohnRoderick is offline   Reply With Quote
Old 11-16-2017, 03:46 PM   #24
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
That would have been really slick,if you could have made it work. I will probably have to modify a fork for mine also.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 11-16-2017, 05:37 PM   #25
JohnRoderick
I purchased a kit for my 69 camaro. I think Bickle sells it.
https://www.flickr.com/photos/141020.../shares/XxJK73
I used it as a starting point then modified the clutch fork to use a Heim joint.
I bought the McLeod SBF bellhousing for my 93 Mustang stocker, it is really nice, thinking of using it on my CJ project. I am not sure about the fork, the stock mustang cable will work, haven't really looked at what I will need for mechanical linkage.
Old 11-17-2017, 06:53 AM   #26
J&S Racing
Liked 327 Times in 87 Posts
Thanks for the info. Definitely saved my $400 on the clutch fork!!! To bad that wont work!!
Old 11-18-2017, 09:31 PM   #27
JohnRoderick
Here are the pictures of the clutch fork that were requested. Credit goes to Phil Mandella Jr. for the fabrication.
https://flic.kr/p/21CcUGo
https://flic.kr/p/21F2k1M
https://flic.kr/p/ZjDY2B
Old 11-19-2017, 12:59 AM   #28
JHeath
JHeath's Avatar
That is nice, thanks for the photos !!!
Jerry Heath
I/S '93 Cobra
Old 11-19-2017, 08:09 AM   #29
J&S Racing
We were talking about welding a heim to the end of the fork but I really like the extra adjustment of that set up!!! Thanks for the pic.
Not bellhousing related but I'm getting ready to re stab the motor and get the trans mounted..... are you guys using any type of trans mount or bolting it directly to the crossmember??
Old 11-19-2017, 11:12 AM   #30
JHeath
JHeath's Avatar
I used a Energy Suspension brand polyurethane transmission mount, Jerico said to use it.
Jerry Heath
I/S '93 Cobra
