Old 11-23-2017, 12:30 AM   #1
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: a lighter battery
Originally Posted by Larry Merk View Post
If you wanted to lose a LOT of weight you could go with a Lithium battery. Pretty spendy at $379, but it only weighs 4 pounds! Made in Colorado.
http://www.batterymart.com/p-ltx680-...0-battery.html
Funny how lithium batteries are so dangerous in airplanes but this battery is advertised as being for experimental aircraft.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 11-23-2017, 12:58 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Experimental coincide with expendable?
Rich Taylor
I/SA - 321
Old 11-23-2017, 05:15 AM   #3
Dickens
Liked 12 Times in 8 Posts
I use a wheel chair battery that is dimensionally small and has quick recharge
Interstate batteries 35 AH rating 22 pounds
DD
Has been in 3 seasons
Dickens is offline   Reply With Quote
Old 11-23-2017, 09:11 AM   #4
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
I mounted a Braille in our Dakota Stocker this time last year and it worked fine this summer in some higher than normal summer days - the only thing I noticed with it was I had to continually tighten the top post adapters all summer till they finally seemed to seat but over all between tire/wheel combo and the battery we moved 44 lbs - just my $.02
BA1927 is online now   Reply With Quote
