Liked 883 Times in 237 Posts
With a small tire like that , shift on the stop . less likely to spin and you will get more MPH
The 3066 is a bias tire so it should handle coming back under power with that low boost.
Question about the single blade TB.
Are you talking about a cable operated TB with a throttle stop, or using a plate under a DBW TB? I’m trying to figure out a solution to this same problem as the OP. I’m currently using a DBW TB, but I can make the switch to cable, if it’s the only way to make it work. Thanks for any guidance. |
#3 | |
Liked 7 Times in 6 Posts
A blade stop will not work with EFI for same reason it won't work with Enderle/Rons injection. You can restrict the airflow all you want, but the barrel valve or ECU TPS will still see WOT and be dumping fuel in. Just for my 2¢ , I agree (especially in my case of being on the heavy side for factory interior; essentially super stock trim) that coming on the stop in high gear will control wheel speed but lose MPH and possible consistency from the motor lugging from basically a 20-30 MPH roll in high gear. On the other hand, coming off the stop in low gear may yield a traction limited situation depending on how the boost curve comes in. I'd like to think that even at 9" wide, a 30" tire with a powerglide and 3.89 gear would be pretty damn hard to spin coming off the stop in low gear. But again, depends on the boost curve. |
Thanks for the reply. Like you, I’m looking at how to adapt a rod to the single blade TB. I could use a 4150 and an elbow, but I’d prefer not.
And as for forcing the blade closed if it hangs open, I have an interior battery cutoff that will kill everything mounted to my shifter. Last edited by C5 Pete; 12-29-2017 at 10:35 PM. |
#5 | |
These are the adapters i've found. https://www.kartek.com/parts/push-pu...-body-cam.html http://www.pacificcustoms.com/cabletb.html |
So, with these adapters, the cable mounts just like a standard cable on throttle body, but the threaded end screws onto the end of the ts shaft?
I was considering welding a rod onto the blade cam of the throttle body to attach the rod, but maybe this cable adapter would work better. |
#7 | |
For what it's worth, I used a Ron's Terminator on the stop for ONE RUN. I got gassed out by the Methanol, so I put the carburetor with gasoline back on. I ran the Terminator on the stop with a solenoid bleed actuated by the throttle timer, through a 90 pill at 3500 rpm. Worked fine
#9 | |
#10 | |
Liked 431 Times in 224 Posts
I'm NA, but in both my S/ST and SC car I come off the stop in Low and shift downtrack on RPM. I lose little to no MPH doing this, and especially in SC I will out-MPH cars that have 200+ more horsepower than I do. It takes a lot of power and time to get the car moving in High gear. Again, if I had a supercharged small tire car I'd be shifting on the stop, but it will cost you some MPH.
S/ST 51 S/C 53 |
