Old 01-22-2018, 06:25 PM   #1
Default LS Hydraulic Rollers
I'm in need of 12 of the Chevrolet GM Performance lifters for a V6 project.
Part # 88958689
All I've found is sets of 16 (Scoggins-Dickey, etc.)
These could be take outs from a S/S engine, as long as they're new.
Any ideas /suggestions?
Thanks in advance.
602-769-0346
myac455@gmail.com
Old 01-22-2018, 07:41 PM   #2
MR DERBY CITY
Liked 8,109 Times in 1,531 Posts
Default Re: LS Hydraulic Rollers
Part # 88958689
Thanks in advance.
602-769-0346
myac455@gmail.com
Yes I have a suggestion.....buy the 16 and you will have 4 spares,.....NEXT PROBLEM.......
Old 01-22-2018, 08:29 PM   #3
Wink Re: LS Hydraulic Rollers
For...??? Wall ornaments?
Thanks for the btt
Old 01-23-2018, 07:59 PM   #4
Bob Shaw
Liked 322 Times in 63 Posts
Looks like a V/SA project.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 01-23-2018, 09:30 PM   #5
It does, doesn't it? But it's not. Of course that would be V/Stick anyway.
No, it's a 231 Buick. Same roller from the GM parts bin.
Old 01-24-2018, 09:23 AM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Just an FYI , I have been rebuilding a 3800 for a Firebird street car and discovered that while the lifters look the same between the 3800 and the Chevy lifters , the pushrod seat is different . You will need about a .100 shorter pushrod if you use a Chevy lifter .
Old 01-24-2018, 12:50 PM   #7
Thanks for that info, Russ
I planned on new push rods too, ordered to the length I'll need, so we'll pick up on that, at that time.
The checking lifter we have is from an LS build too, so should be all good.
Old 01-30-2018, 01:17 AM   #8
Still looking....
Question for the engine builders / COPO owners }
Did all the LS COPO cars come with the close tolerance "bowtie" hyd. roller lifters ?
How about the 2018 cars, now that the rule changed?
I assume they are replaced with a solid roller for Super / Stock.
Old 01-30-2018, 01:39 AM   #9
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Still looking....
The first COPO’s came with the CTS-VR lifters made for higher RPM. Then 2nd and 3ed year cars use the Johnson lifters. Both are hydraulic. I could be wrong but don’t think the 17 or 18’s come from the Factory with a solid lifters... I could be wrong on the new setups.
If you are looking for a good cheep LS lifter the Stock LS7’s are hard to beat for the price. I would be shocked if you can find only 12 just buy 16 and call it a day.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 01-30-2018, 08:53 AM   #10
GTOMayhem
Liked 22 Times in 14 Posts
https://zzperformance.com/3800/camsh...7-lifters.html
Mark, take a look at these.
Rick Thomaosn
GTOMayhem
GTOMayhem is offline   Reply With Quote
