Old 02-04-2018, 11:56 PM   #1
Kevin Love
Liked 19 Times in 10 Posts
Default Re: How much oil?
Go to Turbo Action's website-there is a tech bulletin outlining fluid levels for metric 200s
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 02-05-2018, 12:23 AM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Yes M.J. I have a dipstick, but it is a Lokar and they are tough to read
the same day you put oil in them. I just wanted some other opinions
to get it close when I fired it up. Tough crowd tonight.
J.R. Haddad is online now   Reply With Quote
Old 02-05-2018, 12:38 PM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
Originally Posted by J.R. Haddad View Post
I have a dipstick, but it is a Lokar and they are tough to read.....
Hey J.R., I have a Lokar on my 200 and the 'Full' line is marked nowhere near correctly. As mentioned before, Turbo Action has a great Technical tip on this.
http://www.turboaction.com/frame.html Technical Tip #12
Hope this helps. -Al
"That'll never work....."
Old 02-05-2018, 01:43 PM   #4
MR DERBY CITY
Liked 8,096 Times in 1,531 Posts
I figured you had a Lokar setup, take Parker’s advice....it’s better to be a lil low than to overfill.....
Old 02-05-2018, 02:05 PM   #5
J.R. Haddad
Thanks guys, I appreciate it. J.R.
Old 02-05-2018, 12:40 AM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
It's important that you check the calibration of your dipstick . With a stock pan the " Full Hot" line should be at the same level as the pan gasket . Keep in mind that Full Hot means the fluid is at 200 degF . The factory dipstick also has a min line which is at the bottom of the cross hatch marks . The min line is a full mark at 70 degF. You want to make sure the fluid level never exceeds the Full Hot line , because if the Fluid gets up into the rotating parts , it will froth up like a milkshake . This will cause all kinds of problems , the worst being oil out the breather which, if it gets on hot parts , could cause a fire .
Old 02-05-2018, 09:55 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
If it has an extended pick up on it then you don't need anymore fluid than with the stock pan.
Mike Pearson 2485 SS
