What are you Stock and Super Stock racers using for the required fuel check? New to Stock racing.
Thanks |
Liked 33 Times in 16 Posts
About as cheap as you will find and works... http://quartermax.com/fuel-sample-valve/
Rich Taylor I/SA - 321 |
Thanks so much. Just ordered one.
Ron |
Liked 2 Times in 2 Posts
Just curious but what is the devise being used to check fuel for
chemical content or diaelectic spec.? |
Liked 21 Times in 13 Posts
Here's one w/o the hose: https://www.appliedracing.com/an-fit...ple-valve.html
and a brass one: https://www.mcmaster.com/#7910k11/=1bg9eu0
Brian Carpenter Stock 1358 |
#6 | |
Liked 1,945 Times in 586 Posts
Mike Pearson 2485 SS |
#7 | |
Liked 805 Times in 341 Posts
This looks like it just pulls a sample from the tank. Thanks, Bill |
That one mounts on the regulator. Push in and the fuel comes out of the tube. Release and it stops. Looks like a nice way to do the job. As far as I know you have to take the sample from under the hood.
"Pumps/Valves: Cars equipped with carburetor(s) or nonelectronic
fuel (EFI) systems but with mechanical non-OEM fuel pumps must have a quick-action fuel-shutoff valve within easy reach of driver and located in the main fuel line between the fuel tank and the carburetor and/or injectors. Fuel recirculation systems not part of normal fuel/pump system prohibited. All cars in Stock, Super Stock, Competition, and Pro Stock must be equipped with a positive-lock drain valve located between the fuel tank and the carburetor(s) or fuel injector to facilitate removal of fuel samples for fuel-check purposes."
