Old 02-07-2018, 09:17 PM   #1
Rod Greene
Liked 242 Times in 81 Posts
Default Clutch Switch
What kind of setup are you stick guys using for a clutch switch to control 2 step? I never had a switch on the clutch just button on shifter. Pics would be nice.
Thanks, Rod
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 02-07-2018, 09:51 PM   #2
Don Fardie
Don Fardie's Avatar
Default Re: Clutch Switch
I use a Biondo switch working off the Z bar. It allows you to dial it in so it releases just where you want it to!
Don Fardie 1582 F/S B/G
Don Fardie is offline   Reply With Quote
Old 02-08-2018, 09:25 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Don's setup looks pretty nice.
I may have to try that on my next clutch job !
I've used the Jerry Bickel switch in the past which is a very heavy duty switch with molded in leads and an adjustable arm .
they also have a universal mounting bracket for it.
Old 02-08-2018, 09:41 AM   #4
terry1
Liked 24 Times in 13 Posts
Smile Re: Clutch Switch
What is the issue with a switch on the shifter in Stock.
I believe the SS people are allowed one on their shifter.
Terry K
terry1 is offline   Reply With Quote
Old 02-08-2018, 09:02 PM   #5
Rod Greene
Terry K
Unless the rules have changed again. I believe the stockers have to have 2 step controlled by clutch. It is a stupid rule that just adds extra wiring and points of failure.
Thanks for the replies guys. I am exploring options on the set up. I assume that both those switches have to be adjusted every time the clutch is adjusted correct? Is one more user friendly than the other? I have figured out how to use 2 relays to lock the line lock and 2 step together just working on clutch switch configuration and location for ease of use.
Old 02-12-2018, 01:25 PM   #6
CMcAllister
Liked 920 Times in 259 Posts
I've put these on a number of stick cars for guys. Fab a mounting bracket and a tab on the pedal to actuate it. Infinitely adjustable. Guys like them fine.
Old 02-08-2018, 09:19 PM   #7
Rod Greene
I went on the BIONDO web site couldn't find the switch. Do you have a part number?
Thanks, Rod
Old 02-08-2018, 11:06 PM   #8
Don Fardie
Don Fardie's Avatar
Thanks, Rod
I believe it was a Biondo Transbrake switch, but here is a link to the Jegs version. As far as adjusting it when clutch set up is being changed it's easily corrected to account for any rounds being added or removed.....and that is if any adjustment is really even needed. Good Luck!!
http://www.jegs.com/i/JEGS-Performan...10353/10002/-1
Old 02-11-2018, 05:52 PM   #9
Wayne Totaro
Liked 39 Times in 13 Posts
Rod, I use the Biondo switch. I drilled a hole in my clutch pedal and the switch comes through the hole! When my foot is on the clutch it is activated! Works fine!
J. Wayne Totaro 1117 STK
Wayne Totaro is offline   Reply With Quote
Old 02-11-2018, 09:08 PM   #10
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Rod,
I use an OMRON switch P/N D4C-1620 (actuated by the clutch fork). It looks very similar to the Jerry Bickel switch, but it can be found on ebay for ~$15 new.
Tim
T Ames is offline   Reply With Quote
