Liked 346 Times in 126 Posts
Have a question for the J througm M cars running small blocks. What axles are you running and do you have them gun drilled and hubs milled down to the min.
Thanks |
No Milling or gun drilling on our cars.......
Not enough Bang for the Buck on our Budget. If money is not a big object......Get them and all the ceramic bearings you can find! Set N/SA National in 86 Dodge PU (360) Plus O/SA in Dodge Aspen Wagon (318) Without that stuff......Our money mostly spent under the hood!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 02-12-2018 at 04:04 AM. |
#3 | |
I have 150 sets of heads.....Should have whatever part # you need.!
Just sold a couple sets 318/273 Heads to the Loge Family.
Liked 11 Times in 6 Posts
Gun drilled and star flanged because a 305 needs all the help it can get.
Liked 25 Times in 16 Posts
I never thought the center drilling would help much since the moments of inertia are the highest on the outer diameter. Same for strength, it's on the OD. So you save mostly dead weight not so much on the inertia. If I remember correctly, both strength and moment of inertia is the fourth power of diameter.
Maybe you could run an aluminum spool with the 273? Lighten a steel spool and ring gear might be better options. I bought a Mittler Brothers spool with lightening holes in it last year for about $70. They had a sale, so I thought I'd take a chance with them.
Mopar 2 Ya! |
#8 | |
I have a lightened spool already, and I am going to dump the mopar SS springs for the calverts. |
