Old 02-16-2018, 12:07 PM   #1
Kris Kristofferson
Kris Kristofferson's Avatar
Default Re: Trans shields for 2018
Yes, I tried to phone the company (which in located in Florida I think) to directly order a shield and they were delayed quite a bit with production due to a lack of material. I am unsure how they are doing today.
I ended up buying a used CSR shield locally and it actually fit well on my TH-400 with a stock Monte floor. The trans was already out which made the install much better. I also used a Lokar flexible dipstick (which can have the certified locking end) which helped a lot and have also "hole sawed" some bellhousing acess holes (with covers in the firewall) to make installing the bellhousing bolts much easier..
I am just a bracket guy but hopefully this can help other guys..
Kris Kristofferson is offline   Reply With Quote
Old 02-18-2018, 09:22 AM   #2
Kris Kristofferson
Hey guys, does anyone have connections with a good carbon fibre supplier? Hutch would make them if he could get a good source, he does great trans work you can check it out at YellowBullet..
I'm very aware and forecasted this year's ago. The problem is the carbon fiber people have worn me the heck out. I'm not sure what to do at this point.
Hutch
Old 02-18-2018, 12:29 PM   #3
Hacksaw
Liked 312 Times in 175 Posts
Try Tim Hodgins at Cynergy Composites 519 Two 4 Five 0016 Strathroy On
Old 02-18-2018, 02:45 PM   #4
63corvette
Liked 359 Times in 103 Posts
[QUOTE=Kris Kristofferson;556447]Hey guys, does anyone have connections with a good carbon fibre supplier? Hutch would make them if he could get a good source, he does great trans work you can check it out at YellowBullet
I believe the shields must be SFI certified and re certified every so many years so home made won't get you through Tech.
63corvette is offline   Reply With Quote
Old 02-19-2018, 09:07 AM   #5
Kris Kristofferson
Hey guys contact Hutch at..
http://hutchtrans.com/shop/
Perhaps if enough interest is there, and carbon fibre suppliers are found; a alternate source for shields can come though. If someone here has connections in the carbon fibre world this might help a lot..
I can tell you that the shields would be top notch certifiable units as Hutch is a big time trans guy..
