Old 02-28-2018, 01:18 PM   #1
RJ Sledge
Liked 288 Times in 90 Posts
Default garage sale
Weld AlumaStar 2.0 ftont runner 4.5bc
Weld AlumaStar 2.0 15x10, 4 3/4bc(GM), 5"bs used 9x30 Goodyear radials
Weld Drag Stars front runners 2 sets
Weld Drag Stars 15x10, 4 1/2bc(Ford/Mopar), 5"bs
Afco 3850sp shocks installed but never run
adjustable collar ride height set up
used M/T 29x4.5 front runners
REF FE headers 66/67 Fairlane/Comet 4-1's and Tri-Y's coated nice
JPT C4's 2.75 and 2.92 transmissions
ATI Converter 5800-6000 in my Stocker
"N" case R/E 4.86 35 spline steel spool
4.63-5.29 R&P's
Strange Aluminum center section empty
Strange Aluminum R/E 5.00 35 spline Strange Aluminum spool
Moser axles 35 spline rifle drilled profile milled flange stock Mustang/Fairlane length 5/8th studs
Yukon "N" case 35 spline Strange aluminum spool 4.63
390-428-427 cranks
2 427 Ford blocks
Crower 6.480 Ford journal size fresh new Crower bolts and sized
Ford PI Aluminum Intake
390 Stocker motor complete(Edelbrock by Kuntz, T&D rocker, Trend, etc) may seperate
Extra C6AE-R cast iron heads complete fresh by Kuntz
Schubeck solid lifter dyno time only .875 Ford
Canton 2 quart accumulator
Aerospace front and rear brake setup
Turbo Action Cheetah C4 rev pattern shifter
plus alot more
21zero-3seven3-four 0 zero 4
Thanks RJ
RJ Sledge is online now   Reply With Quote
Old 03-01-2018, 11:39 AM   #2
kyhemi-dart
Default Re: garage sale
Sent you a text
kyhemi-dart is offline   Reply With Quote
Old 03-01-2018, 06:29 PM   #3
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Hi RJ. I am interested in the strange alum 9in case. What bearing size is it? Is it the lightweight case? Price? Also what are you asking for the transmissions? Don't need the bellhousings as we run small blocks. Thanks.
'65 Mustang SS/L & L/SA
Old 03-01-2018, 07:58 PM   #4
nickh
nickh's Avatar
Liked 659 Times in 197 Posts
Pm sent
Old 03-03-2018, 11:16 AM   #5
mannymen
Liked 13 Times in 7 Posts
PM sent regarding 390 and spare heads
N/A
mannymen is offline   Reply With Quote
Search this Thread:
Advanced Search
