Old 03-02-2018, 05:38 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Sfi 200 metric case
I was looking to see how much interest there would be in an SFI approved TH 200 Metric case.
I would think with all the people using them in stock & super stock, a corporation that builds this type of case would stand to make a nice profit given the new 10.99 rules?
Would you buy one if it was available, instead of using a blanket or shield?
I'd take one!!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 03-02-2018, 05:44 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Sfi 200 metric case
I see ATI just released a SFI case for a 350THM . They may be a good place to ask, if there is enough interest in the 200 .
Old 03-02-2018, 06:27 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Seeing I have five th-200's I'd be good for 5.
Lee Valentine 1661 STK
Old 03-03-2018, 02:48 AM   #4
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
The 350 case will not be available until end of season.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 03-03-2018, 01:03 PM   #5
SSDiv6
Liked 1,583 Times in 582 Posts
While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case.
Old 03-04-2018, 04:22 PM   #6
Todd Hoven
Guest
Posts: n/a
The point of the SFI case is not only because it’s stronger, it is so you don’t have to purchase a blanket or shield. A different production case doesn’t solve this issue
QUOTE=SSDiv6;557372]While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case.[/QUOTE]
Old 03-04-2018, 07:48 PM   #7
SSDiv6
Originally Posted by Todd Hoven View Post
The point of the SFI case is not only because it’s stronger, it is so you don’t have to purchase a blanket or shield. A different production case doesn’t solve this issue.
Correct, however, there has been an issue with cases cracking and the reason why they sell braces to prevent the cracking.
Old 03-04-2018, 10:49 PM   #8
Liked 5,125 Times in 1,953 Posts
Joe, Did they make a 3 speed diesel case?
Old 03-05-2018, 10:34 AM   #9
SSDiv6
Yes they did. GM cars, including Cadillac that were powered with the Olds 260 and 350 Diesel engines, depending on the year, had either the THM-200, THM-200C or THM-200-4R transmission. All the cases were BOP and beefier.
However, the first year the engine was introduced, 1978, the transmission was a T-250.
I learned about it from a former colleague of mine, that was a drivetrain/transmission engineer at GM. On the side, he rebuilt transmissions at home. He heard me talking on the phone with another racer about the T-200 trans and he asked me if I needed a stock transmission. Also gave me a dissertation of all the GM transmissions and told me he had a BOP T-200C and he rebuilt and didn't have a use for it.
He shared the transmission had a beefier case for the diesel application. When I picked it up, he was not kidding. The bellhousing and case were beefier and did not look like the case of a T-200 I had purchased from TurboAction.
Old 03-02-2018, 07:00 PM   #10
NHRA3106
Liked 143 Times in 37 Posts
I would be interested in one
NHRA3106 is offline   Reply With Quote
