Old 03-26-2018, 03:01 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Stocker Cam
Just ordered a Stocker cam from Bullet..
Going to be using the stock PCM...limited to 7000 rpm..!
Using a 8.5 inch Rear with Street Moser Axles.
Have 4.56's, guessing 5.15 or 5.38 with 30 inch tires.
Running a PerfomaBuild 4L60E with a Yank 4400PT locking Converter.
Seeking advice where to get to.
D
Old 03-26-2018, 03:10 PM   #2
GUMP
Liked 2,359 Times in 557 Posts
Default Re: Stocker Cam
D
As that thing has a pretty deep first gear, I would try the 4.56 first. It will probably want a bunch more stall.
GUMP is online now   Reply With Quote
Old 03-26-2018, 04:25 PM   #3
Dan Fahey
Dan Fahey's Avatar
Can you put a non locking converter in a 4L60E that uses a Locking Converter?
D
Old 03-26-2018, 04:26 PM   #4
GUMP
D
best to talk to ATI on that one......
Old 03-26-2018, 04:54 PM   #5
D
Yes.
On the cam..What duration ? You may find that the vacuum parameters are outside of what the stock ECM likes.
Old 03-26-2018, 06:54 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Are you running a MAF sensor ? You won't have any problems putting a non-lock-up Race converter on a 4L60-e, but you will be giving up a few mph on trap speed .
Old 03-26-2018, 07:06 PM   #7
Liked 1,892 Times in 423 Posts
Biggest problem will be the severe drop between 1st and 2nd gear. By the way, Sonnax now has the cure for that.Which will allow you to run a lower rear gear.
Old 03-26-2018, 07:35 PM   #8
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Hey Dan,
I talked to Charlie at ATI for my 8" non lockup for my 4l60e and Ed Wright removed the lockup from the PCM. Also, Ed said to use a 96+ PCM because a 95 won't allow a stall above 2200ish. I haven't run the car yet so can't comment on how it will run.
FrankM is offline   Reply With Quote
Old 03-27-2018, 07:25 AM   #9
GUMP
Anyone ever try running the lockup in third? I am curious if it helped or hurt.
Old 03-27-2018, 11:25 AM   #10
Dan Fahey
Dan Fahey's Avatar
Yes using a MAF sensor..
Have not used the Locking part yet.
Is that common?
Dan
