#11 |
No problem ,bro.
We don't have tech in NHRA anymore either.
#12 |
Liked 38 Times in 17 Posts
Definitely some engine changes for those cars in that year range. Early ones had the aluminum intake manifold with forward facing throttle body, later had a plastic intake with throttle body facing the driver side. I believe the plastic lower intake on the later ones is the same as Mustang with just the aluminum upper elbow being different to point to the opposite side. Both intakes are pretty restrictive. The plastic one also always cracked and leaked water, I don't think the updated part number with the aluminum water crossover is in the engine specs, would need to go through the process of getting that approved. There should be a cylinder head change somewhere in that year range, the ports got straighter at some point, I think around 96.
K Danner STK 468 |
#13 | |
Liked 372 Times in 130 Posts
My first thought was WOW !...that's one quick 2 valve
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#14 | |
#15 | |
I'd like to extend an invitation to this fellow to bring that thing to the US Nationals. There will be a fella there named Travis Miller..Long time Ford man. He'd love to check that car out.
#16 | ||
"it has a big cam, big intake, big compression, big heads and big cubes" "TFS intake, TFS heads, 90mm maf, 3.5" intake tube, 75 mm throttle body (too small), Bullet custom cams, 12.5/1 comp ratio, big bore/stroker 5.3 Liter, Eagle crank, eagle rods, SHM 1 7/8"-3" long tubes, 4500 stall converter, 4:56 gears. E-85 for fuel."
K Danner STK 468 Last edited by kdanner; 03-28-2018 at 09:00 PM. |
#17 | |
#18 |
I think worse than that, a 323. Looks like the 3.75 Eagle crank plus a 3.7 bore.
K Danner STK 468 |
