Old 04-04-2018, 02:50 AM   #3
jmantle
Liked 172 Times in 81 Posts
Default Re: Engine size change
Originally Posted by kevin54 View Post
I have a 1978 Mercury Cougar with a 351w 2brl that should run in Q/SA. I would like to know If I could change to a 302 2brl and run U/SA?
If I can change to a 302 will the short block have to be a 1978 or is there some leeway on the year? I understand that the Intake, carb and heads year and model specific. I'm new to the Forum Thank you for your help.
It's in the guide at 139 HP and 27 pounds per HP. I doubt if you could get it light enough to be competitive even with the soft HP rating.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
