#91 | |
Liked 72 Times in 27 Posts
#92 |
Banned
Liked 235 Times in 110 Posts
#93 |
Liked 89 Times in 19 Posts
No system, regardless of how carefully it is designed and how thoughtfully it is implemented, can long survive a period of either benign or pernicious neglect. There are sufficient numbers of individuals who are intent on gaining an advantage by any means available to render even the most comprehensive rule book irrelevant practically overnight. This is especially true of the Rules of Engagement in Stock Eliminator.
Chuck Norton |
#94 |
Liked 21 Times in 13 Posts
well said, as is un-comfortable or satisfying it may be.
Brian Carpenter Stock 1358 |
#95 |
Liked 520 Times in 132 Posts
I know two SS racers who switched to aluminum heads over the winter and both slow d down........their not happy either 😳
#96 | |
Liked 8,052 Times in 1,529 Posts
#97 | |
Liked 783 Times in 195 Posts
#98 | |
Guest
Posts: n/a
One of the candidates for a replacement head for Pontiac round port was a head made by Kaufman Racing. Everything was a go but Bruce rejected it because of angled spark plugs. Guess that is not a problem anymore as long as you race a Chevrolet.
#99 |
Liked 184 Times in 113 Posts
This is where I will miss the IHRA Pure Stock.
Basically the Old Stock Eliminator Rules. Seems about that same time in Class Racing. NASCAR Stock Cars had less and less original components! Now not one part in modern day Stock Car ever fit on a Production Car. Same with our car. We need Roll Bars, special suspensions, more safety equipment, certification of helmets and seat belts, special fuel. Cannot even use pump gas anymore. Crate Motors were always a natural fit. Replacement engines were always common. Did not morphed the Stock Eliminator concept. Sometimes you are stuck with a combination. Old parts become problematic! Plus opened up a vendor base. We may not want another class but new ones are always being invented. The RAGE of Racers complaining they do not want a new class. New ones keep popping up. Which means Stock Eliminator has to compete for Racers who choose to run those classes. Current rules restrict inviting the new generation of Racer to play in our sand box. You do not do not see many 20 - 30 year olds. Do see 50’s, 60’s, 70’s and 80’s and passing away. IHRA had the right idea with their Class Eliminator set up. Had NHRA adopted the IHRA structure. There would have been shift from traditional Stock. D |
#100 | |
Liked 140 Times in 46 Posts
Jon Sarrett Stock 3779 |
