#31 | |
#32 |
I like the idea of the new cylinder heads. It’s getting harder and harder to find the old heads we have aftermarket companies like Jones trying to make the sport better The head is available to everybody NHRA can still tear you down can still look at it Dominic Camera 7777 SS
#33 | |
The Jones cylinder heads, including two of the Edelbrock approved heads, have an an angle plug configuration. I believe that about 95% of the Chevy small block engines, use an OEM straight plug configuration. Dwight Sutherland made a very clear statement on his posting regarding the fact that these approved cylinder heads completely deviate from what is stated in the rule book. If the intent was to offer a replacement to the OEM cylinder head, why not offer it with the OEM straight plug configuration? Does an angle plug offer a power advantage? Yes they do! |
#34 | |
Liked 124 Times in 39 Posts
Sean Cour T6066 ladle |
#35 |
Liked 79 Times in 7 Posts
Erik,
I have a question maybe two. When "Jones engine development" woke up that morning and said I'm going to create a head that will level the playing field in S/S. What did he have in mind? Did you go into it saying I'm going to keep all the same issues the current heads have had for the past 50 years? Such as areas. When you made your core boxes for your head did you have the sizes and shapes of a modern s/s port in mind and put the water accordingly? If I was getting ready to spend that kind of money I sure would of had to have that in the back of my mind. Erik in no way am I getting on here to try to belittle you. The form was just opened up to try to clear up some questions for everyone. I understand that there are other heads approved. And if they do it for them they should do it for Jones development Manufacturing. I'm sure your spacing and angles are correct I wouldn't question that for a minute! But all the other heads Alum and cast other than the" 2nd dart head" were as cast port heads that the manufacturer came up with as a replacement to put on your street car. Rather than spending money on old iron. And put the water jackets in them accordingly. I'm sure you have worked on your fair share of these aftermarket heads. And you would have to admit you run into the same issues as a stock head. I'm in no way saying that starting with a clean sheet of paper wouldn't be nice but I think this might not be the place to do it. I wish you all the best and hope you get the reward for all your hard work you have put into this. Just my thoughts |
#36 |
Liked 565 Times in 70 Posts
Erik obviously had an idea and did the work to get this head approved through the existing procedures set down by Nhra.
It appears to me that there are 2 main points of concern. The first is that these are angle plug heads. If some manufacturers angle plug heads have already been approved, why, if you were developing a new head, would you not be angle plug? That ship has already sailed. The second point is that there is material left in the runners that allows porting without extensive or even any welding or epoxy. I just don't see a downside to this. It allows every engine builder to search for the perfect runner with less labor. If he feels the perfect runner is already availiable in another casting then of course stick with it. The sport we've chosen is not cheap. It's made up of a lot of smart, hard working people who come up with ideas to improve the performance of our cars, within the rules of Nhra. This seems to be one of those ideas. Yes, I am Eriks friend and customer and hope he develops a big block mopar casting before I'm on Medicare. My opinion |
#37 |
Liked 358 Times in 83 Posts
#38 |
First off I would like to thank Mr. Jones, I consider him an innovator in our sport and along with that comes controversy. If the heads listed in his website are approved by the NHRA and meet OEM Specs when finished, along with a HP. Penalty for the replacement heads, what’s the problem?
As for me I will welcome to new Heads, as I have experienced water leaks on every pair of heads I have purchased. The porter heads would be a cheaper alternative. Ron Terrell SS-3215 |
#39 | |
Liked 47 Times in 6 Posts
Justin started this post for an open discussion for the topic of this cylinder head, I have done my best to stay professional thru this. To answer your question if i am doing an engine for Dominic the answer is yes. I gave him the same answer i gave you when you asked me to do an engine for you guys after Indy...."I'm a year and a half out" the only difference is Dominic said yes. In my opinion the only reason you are against this being approved is because i am taking the advantage away that you think you have. Remember i stood right next to you in the barn at Indy with your cylinder head in your hand... I have been looking at cylinder heads for a long time and i know what i am looking at. NHRA can only police what is written down and what they can measure and we both know that. Now there is a casting that everyone can buy to start on a level playing field. Tilburg, Yesterday your comments showed that you didn't understand the way a cylinder was made and today you are talking about casting boxes.... The only thing i can say on that is if you think spark plug location and water jacket on an aluminum aftermarket head that has to end up 172 ccs makes a difference in how it runs then you are working in the wrong area. I've done my best to answer legitimate questions without beating around the bush, this is a serious topic about someone who is trying to make your lives easier if you don't wan't that then that's fine with me. I have already contacted NHRA about changing the plug location and or removing the heads from the list. In the end my customers still get the best that i can do at that time regardless of what i start with. Judging from the 30 phone calls i received yesterday your implications are acknowledged, so let the cards fall where the may gentleman.
Erik Jones |
#40 | |
Liked 520 Times in 132 Posts
