Old 04-20-2018, 05:30 PM   #31
MR DERBY CITY
Liked 7,968 Times in 1,524 Posts
Default Re: Trans shields for 2018
Originally Posted by Bill Moulding View Post
I just installed a trans shield for my 4th gen Camaro on a metric 200. Came from Tom Waters Race Car Products. It bolts on to two brackets (supplied) that attach to each side of the pan rail. No twisty straps. Fits real nice and did it with the trans in the car. They can be reached at 407-240-8626. Bill Moulding
Thanks Bill, just curious, Do you run a brace ? Do you use a cheetah shifter ? You had better results than a lot of guys....MJ...
Old 04-21-2018, 01:26 AM   #32
Michael K
Liked 62 Times in 17 Posts
Originally Posted by nssracer View Post
Have fun trying to put a shield on a A-Body Mopar....won't fit had to use the Jegs blanket....pain in the a..
I'm guessing that the blanket may not fit at all on an A-Body big block/727.
Michael K is offline   Reply With Quote
Old 04-21-2018, 09:48 AM   #33
Bill Moulding
Darrell sorry I never took any pics. I had the use of a friends hoist and its back in the trailer now.
MJ I use a B&M Prostick and its trans bracket went on with the same bolts as the shield bracket (with some light massage). No brace.
Bill Moulding
Bill Moulding is offline   Reply With Quote
Old 04-21-2018, 10:17 AM   #34
MR DERBY CITY
Bill Moulding
Thanks.....
Old 04-21-2018, 11:09 AM   #35
John Nechiporchik
Liked 13 Times in 7 Posts
I also just installed the Tom Waters shield on my metric 200. I had a new brace made to allow the shield to fit. The new brace had a slight interference with the Lokar dipstick, so I also re located the dip stick to the location in front of the servo that was originally used for some sort of a kickdown cable. Masta Performance in Michigan makes a dipstick tube to fit this arrangement and it fits perfectly and has a bracket that bolts to the bellhousing. It is Masta's P/N 200TV.
I use a Hurst Quarter stick and the cable bracket that mounts to the trans required some tweaking (grinding for clearance).
John Nechiporchik is offline   Reply With Quote
