#21 |
Liked 3,202 Times in 977 Posts
What’s the best source for a brake pressure switch? I’ve also avoided a button on the brake petal, just another thing to put in the starting line procedure.
#22 |
Liked 68 Times in 22 Posts
Sorry but I do not have a brake pressure gauge. Sounds like I need to install one. My car is fuel injected. Will I need to change my tune up while I am on the 2 step. My car work really good running off the foot brake. Im very new to stock and the fuel injection game. Thanks.
#23 | |
Liked 586 Times in 162 Posts
#24 |
Liked 251 Times in 125 Posts
Do you use a practice tree? I found that it helped me narrow down the range of the lights I was cutting. Then I was able to zero in on when to leave.
Of course, if they eliminated reaction time, none of this would matter. :-) |
#25 |
Liked 101 Times in 52 Posts
#26 |
So then you prestage bump in and check brake pressure then look at the tree and get on the two step? I don’t mean to sound synical, just want to make sure of the process and if this would help me
#27 |
Liked 42 Times in 17 Posts
ok this is gonna sound stupid but try ankle weights used them on my stick super stocker was going 10-15 red try 5pd weight
#28 | |
Liked 502 Times in 130 Posts
Everyones staging method is different, I don't look at the gauge, I listen for the two step if I am running it. My dakota fuel injected two step process is totally different than the footbrake gremlin(I don't run the pressure switch two step on it, just a gauge) Two step is just faster for some cars/trucks. I like footbraking more. Even better is a stick, now that is where the fun factor really comes in, lots of variables you can tweak to adjust RT, but don't ask me specifics, I'm a novice. Eric
Eric Merryfield 1883 STK |
#29 | |
Liked 695 Times in 201 Posts
Good advise here. Your car if set up the same each run is going to react in just about the same amount of time each run, the variable is the driver. I worked my super gas car down to decent repeatable lights on a Pro tree. I then ran it in super street and was consistently early. (I needed to adjust the car to the slower light) That was accomplished with making changes to the car. Then I went and ran some full tree classes and I was all over the place. The car was still the same and I knew it could cut decent lights on either Pro tree. The difference in the full tree races was squarely with the driver, me. I needed to find a way for the driver to be better at reacting to the full tree, blocking or leaving on the top bulb are some of the ways to accomplish that. Last edited by Mike Gray; 05-17-2018 at 01:09 PM. |
#30 |
Drop front to 17psi
