Old 06-19-2018, 11:19 AM   #31
Marty Buth
Liked 232 Times in 39 Posts
Default Re: Track Prep At National Events
Seems like there are several other methods to slow the pro cars down, that would be a lot safer ways to do it.
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 06-19-2018, 02:43 PM   #32
71mavlouisville
71mavlouisville's Avatar
Liked 28 Times in 1 Post
They are trying to bring the average down before the end of June, so they don't get hit with the AHFS. jk
Yes, it is slower
Ashton Hudson SS/CS 4373
71mavlouisville is offline   Reply With Quote
Old 06-19-2018, 04:08 PM   #33
voltdr
Liked 100 Times in 51 Posts
I agree, but the issue is the fan base. The fans have been paying to see TF run low 3.70s @ 330+ and FC run 3.80s @ 330+. The fans would not show up (look at the grandstands at Bristol) for slower runs.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 06-20-2018, 09:35 AM   #34
Jake Sealey
Liked 10 Times in 3 Posts
We spun in the semi's at Atlanta after making 6 good runs on the weekend. It looked like Strickland in the Copo stocker spun in front of me. We have a similar tire size and run the same ET's, so I chalked it up to track temp and bad luck. But one can only wonder if the reduction in track prep played a role.
You would think you could cross track prep off the list of variables at a National Event.
Jake Sealey
2507 Stock
2075 SuperStock
Jake Sealey is offline   Reply With Quote
Old 06-20-2018, 06:28 PM   #35
Randall Klein
Liked 316 Times in 67 Posts
Unless I’m misremembering, an earlier post said only the last half or third was cut, if so, that shouldn’t affect start hit
Old 06-20-2018, 07:21 PM   #36
Nmbr1GMfan
Have they been spraying the track with two different rigs? I can't see that happening.
Todd Greene
Old 06-20-2018, 07:41 PM   #37
James Perrone
Liked 1,851 Times in 432 Posts
They don’t seem to be dragging and preparing the track between classes
james perrone 1290 STK
Old 06-20-2018, 07:49 PM   #38
Randall Klein
Shouldn’t 2 rigs, nozzle or mixture switch
Easypeazy
Old 06-20-2018, 09:49 PM   #39
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
I haven't seen anywhere that they are using 2 different mixtures. Just the cut down on glue percentage as previously stated. If you check the Fuel Classes, there's been very few good side by side runs with lot's of cars going up in smoke at the hit, hazing the tires, dropping cylinders and grenading engines since the change.
I know, some are going to say that's a normal weekend for a fuel car but this is way worse and not in any particular lane. The idea was to force these guys to take power out. Pretty much ruined the show for the fans and cost racers a lot of money. Next enhancement please...…….
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 06-21-2018, 07:39 AM   #40
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
GOOD ! I like that as I am not a fan of nitro cars at all. ! Would it not be safer and simpler to cut down the percentage of nitro, get rid of one fuel pump, cut back on blower boost or blower size. Cut back the engine size over the down time this coming winter to say 426 or 400 cu. inches for the 2019 season? Then they could go back to racing in a real 1320 ft (1/4 mile) again.
