Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 04-01-2018, 10:43 PM   #1
John Kissel
Liked 230 Times in 94 Posts
Default Replacement parts
Has anyone out there noticed that the quality of; re-built or new parts is just not like it used to be. These are name brand parts from quality dealers. Things like: wheel cylinders that are not machined properly, brake boosters that leak vacume, headers that yout can't get the mounting bolts in, alternators that are weak,and my favorite, a 4 corner idle carb that comes with a 2 corner idle throttle body.I try to buy the best things that I can, just getting tired of fixing new stuff. The carb has become the best one I have ever had thanks to a Quick Fuel throttle body. Thanks for reading, John Kissel K242
John Kissel is offline   Reply With Quote
Old 04-02-2018, 02:54 PM   #2
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Default Re: Replacement parts
I agree and have also noticed aftermarket tonneau covers, grille guards, tube steps, truck tool boxes etc are name brand yet lacking quality. Fitment often poor, workmanship appears unfinished at times etc ... The prices keep going up and often the quality going in the other direction. Many speed parts need modification just to fit properly, like oil pans, headers, even had spark plugs that were not grooved and should have been. A couple new lug nuts with no threads what so ever ... Oops!
Old 04-02-2018, 03:49 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
In the Machine Shops they used to have a scrap barrel, that if a part was out of tolerance the machinist chucked it into the scrap barrel and made a new part that pass inspection before it left his machine.
Now they have eliminated the scrap barrel and will ship out anything. We noticed this starting to happen about 20 years ago and it has only gotten worse.
Everything from engine bearings to windshield wiper blades doesn’t fit.
Because in shipping out their scrap parts they might slide a couple through and have the end user pay the price...
QC inspection has been dead for a long time..
Bob Mulry 7516 STK
A & M Motorsports
Old 04-02-2018, 07:28 PM   #4
pmrphil
Liked 392 Times in 153 Posts
Q.C.? Seems it's getting to be a thing of the past. Just opened a set of rockers to find one of the pushrod cups has NO hole in it. Solid. And everybody thinks I'm nuts for double-checking everything.
Phil Molski
PMR Performance
S/C 1623
Old 04-08-2018, 08:19 PM   #5
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
I know one of the big chains that bought another chain(the purchased chain had better parts) and I asked a regional manager how the merge was going. He stated it was going well, they were able to put their parts in the purchased chains boxes-more profit. I imagine customers will eventually figure it out.
Mike Moller
NHRA 203 Q-R-T/SA
Old 06-29-2018, 11:34 AM   #6
Carguy49
Liked 3,020 Times in 722 Posts
Quality control, along with customer service is going away rapidly. It is hard to find a parts guy or gal that actually knows what you want. If it's not in the computer, they can't help you. I am, of course, referring to the local parts houses.
I totally agree that if you do buy parts, check them for fit. They may, or may not be the right ones.
Ron McDowell - Did Race
Old 07-22-2018, 01:27 AM   #7
John Kissel
Dorman window regulator with motor #741-674 '95 F-150 driver side, wires reversed in the pigtail. Up is down & down is up. Had to reverse wires at the switch. Gotta' love them chikneese parts. John Kissel
Old 10-31-2018, 04:13 PM   #8
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Got a box of new spark plugs, one of the plugs had no threads! Press fit for a stripped hole I guess.
U/SA
79 Mustang
Old 11-03-2018, 12:44 PM   #9
Project 392
Liked 27 Times in 16 Posts
I found an Autolite plug like that in 1968. Think it's still floating around in one of the tool boxes.
Victor in Kingman
Project 392 is online now   Reply With Quote
Old 11-04-2018, 12:35 PM   #10
voltdr
Liked 100 Times in 51 Posts
I had this happen on an MSD extension cable for a crank trigger. I sent the pic to MSD, they confirmed that I should swap the wires. I don't think they (companies) do it on purpose but....................
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
