#1 | |
Ed Wright 4156 SS/JA |
Liked 133 Times in 76 Posts
Why a one wire? You can cut power to the exciter circuit eliminating any load at WOT.
Most race cars don't still have all that factory wiring, one wire alternators are more popular for race cars, engine swaps, etc.
#4 | |
Liked 53 Times in 38 Posts
Something doesn't sound right to me? What rpm are you turning? Alternator could be tuning way to fast and that's the power loss, 3000 rpm is way more than needed. |
#5 | |
Liked 70 Times in 29 Posts
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#6 | |
#7 | |
By the way, loved Jr Stockers back then. Mike |
Liked 126 Times in 61 Posts
Powermaster makes a single wire alternator with and adjustable regulator. I run mine at 15volts, not enough to hurt the battery because its not running that long. If I remember correctly 750 watts equal one HP. So a 100 amp alt. at 12 volts is 1,200 watts less then two HP.
#9 | |
ET slips certainly showed more than I would expect from 2 hp.
On the one wire alt. if your battery is in the back how are you wiring it? I run a powermaster one wire, been on the car for almost 20 years and had to replace the regulator once. I've spoken to Powermaster,Mechman and East Coast electric and they say to run direct to battery, not the cutoff switch. They said that shutting the power off while the car was running could hurt the alternator and they don't recommend it. Called NHRA and they were very vague about having power at the alternator all of the time even with the main power switch off. I know many tracks when they tech will shut the car off from the cutoff switch as their test.
I'd say shutting off the power to a 1 wire alternator at WOT would not be recommended by the manufacturers. |
