Old 07-20-2018, 10:06 PM   #11
Jim D'Amore
Sponsor
Jim D'Amore's Avatar
Liked 66 Times in 17 Posts
Default Re: Poking the Bear Ford Performance Products
Originally Posted by Brett C View Post
Oh really?!
Good evening Brett
Yes you have one fast hot rod I was there when you went 7:80s
Definitely not a fair comparison you are super stock to the maximum... you have almost twice to tire a trans brake so you can leave with full boost bigger camshafts ported cylinder heads extremely expensive valve train and hand fabricated intake manifold both upper and lower and everything else super stock allows you. Ok so now you moved to what we would have to run Factory lift camshafts Factory intake manifold Factory non ported cylinder heads Factory valve train no trans brake and a little teeny tiny Tire and there you have your 8:20 to 8:30
Trust me I would love to run your combination in The Showdown it would take a lot to try to manage it on a small Tire.
Jim D'Amore
Jim D'Amore is offline   Reply With Quote
