Liked 370 Times in 101 Posts
Has anyone ever weighed a 26' trailer ?
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 100 Times in 51 Posts
It doesn't matter what it weighs, unless you reclassify it. The GVW is what they look at. The fact that you are being compensated for transporting this vehicle to and from events makes you commercial and all the rules apply. Log Book, or ELD, US DOT numbers, physical, drug card. same as OTR drivers. Limited driving time.............................................. .................................................. ....................
Dan
Dan Foley SC 4698 |
Liked 319 Times in 82 Posts
A CDL is required to drive any of the following vehicles: Any combination of vehicles with a gross combined weight rating (GCWR) of 26,001 or more pounds, providing the gross vehicle weight rating (GVWR) of the vehicle being towed is in excess of 10,000 pounds.
If truck and trailer weigh 10,001+ a DOT # is required. I'm not sure at what point you need a log book but if you do....... a ELD must be used unless the engine is 99 or older. There is also the short haul exemption. If you travel 100 air miles and return home every night no log needed. Then that has the rolling 30 exemption, this states you can travel outside the 100mi 8 days out of every 30 working days. Now I've asked 3 DOT officers if you can stay out on these 8 days but received 3 different answers. There's also a motor sport exemption. Lol My advice, do everything not to get stopped. Biggest thing I see guys getting pulled over for is traveling I'n the truck restricted lanes. This is even if your towing a open trailer. If you do get stopped, don't ever give DOT attitude!!! They will ruin your day quick!! |
Liked 353 Times in 102 Posts
[QUOTE=J&S Racing;568727]A CDL is required to drive any of the following vehicles: Any combination of vehicles with a gross combined weight rating (GCWR) of 26,001 or more pounds, providing the gross vehicle weight rating (GVWR) of the vehicle being towed is in excess of 10,000 pounds.
Not totally true. If the vehicle is a personal vehicle titled in your name and registered RV and you own the entire contents personally you only need a class A or B depending on the vehicle being towed. Under 10,000 lbs Class B over 10,000 class A. Called a Non Commercial CDL with no log book etc. What I currently have. My 2 Cents Rick in TX |
#5 | |
[QUOTE=63corvette;568744]
Class B pertains to strait jobs only. |
#6 | |
[QUOTE=J&S Racing;568748]
Class B is for a greater than 26,000 lb vehicle only. My motorhome is 33,000 dry and requires a Class B. To obtain my license I took the CDL written test and a Driving Test in the motorhome just like the CDL test. Just no physical or drug test required. I do not have the regulations in front of me however, I carry copies of those pages with me in my motorhome to be able to show them to an officer should he want to see them. Just best not to argue with the officer who stopped you but you can with his supervisor if needed or the judge when in court. The key is you are not commercial if you own all of the rig and contents, it is registered as a RV in your name, you are the driver, and you are not a for profit operation. I just carry my hobby toys in a big rig. My 2 Cents Rick in TX Last edited by 63corvette; 07-31-2018 at 10:15 AM. |
Liked 10 Times in 6 Posts
If your truck is 2000 or newer, you don’t need Eld if do 8 or less trips a month.
Tom Moock 5704 STK |
#8 | |
And from what I'm told the rolling 30 exemption and those 8 days the vehicle still needs to return home every day. This is the problem with the whole deal. Everyone has different interpretations of the rules even the DOT officers but they don't mess around. They would rather hand you a fist full of tickets and put you out of service and let you fight it out in court. I know this won't pertain to op but fuel is probably the thing that can get a racer in the most trouble!! If your not hazmat compliant fuel must be in no more than 4 dot approved 5 gal containers that are secured. And for the record your fuel cell in NOT dot approved so if you get on the wrong side of a officer they can get you for that. |
Liked 476 Times in 117 Posts
Thanks I’m really confused now ... even two lawyers are fighting .... I’m gonna get a cdl seems like that’s when they keep you stranded other issues result in tickets except hazmat and illegal stuff. Investigating if I work for the owner and Do not get paid to transport per say might be ok ... all is under 10,000 each and 20,000 gross. If it ends up a deal I’ll call you from jail 😏😏
Jack McCarthy 3609 STK "the Captain" |
Since the motorhomes have been mentioned... this is a FL license.
Todd Greene |
