Liked 310 Times in 174 Posts
There is usually a small flat area on the upper control arm or check where the original rubber bump stop was located. Directly under this will be a flat, meaty spot on the frame. Drill a 1/2" clearance hole and weld a 1/2" nut to the control arm. Buy some grade 8 hex bolts, 2 short and 2 long ( to suit ) and get a couple extra nuts to use as a jam nut. Just be careful that you locate the welded nuts so that the bolts will hit the frame where you want it to and Bob's your Uncle and Mary's your Aunt.
Liked 799 Times in 236 Posts
Energy Suspension makes a variety of bump stops. -Al
https://www.energysuspensionparts.co...sal_bump_stops
"That'll never work....." |
Liked 7 Times in 6 Posts
The issue I have is with limiting the lower control arm. The platform I am working on is known for ball joint failures, especially uppers. So I would rather limit the lower since it's the one that will have all the spring pressure against it. Ideally it should top out the shocks before getting to that point, but I don't want to pressure them being topped out if I can avoid it.
A fellow in Florida with the same platform truck (occasional highway drive, runs 5/9's) has an ART 3/8" steel cable ran from the sway bar tab, through the compression bump stop chassis mount, back to the sway bar tab. But it seems that the cable setups are hard to come by, I couldn't find that setup anywhere on ART's website. Note sure if these photos will come through...dirty is my truck, shiny is the one in Florida. He has 2" drop lower's, so they look different but function equivelently. |
Liked 333 Times in 180 Posts
competition engineering part # 2025 might be something you could use--FED 387
