Old 09-01-2018, 10:33 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: What factors Determine Tow Rating
X2, also in one of the related threads someone mentioned the financial benefits of possibly just renting a truck for towing a trailer a few times a year. Not wanting to use my Motorhome for a quick 5,000 mile trip to pick up my new race car I rented a 3/4 Ford from Enterprise Rent a Truck and with the 6.2 gas motor it performed flawlessly for far less $ per mile than I could have done otherwise, new trucks are so pricey renting may make sense for you as well.
Good idea!
Especially for long hauls.
Not going to tow more than 6000lbs.
Save the wagon for local trips.
D
Old 09-05-2018, 04:04 PM   #2
Dustin Ward
Liked 4 Times in 2 Posts
If you want to see the criteria that is used to determine how tow rating is actually calculated, look up "SAE J2807" on your favorite search engine.
This is the standard all auto companies use since about 2013 if my memory is correct.
"In response to the confusion that resulted when buyers wanted to compare maximum tow ratings, the Society of Automotive Engineers (SAE) has developed the J2807 set of recommended practices. The tow test procedures designed by the big brains at the SAE consist of a series of rigorous real-world challenges to determine the Gross Combined Weight Rating (GCWR) of a vehicle and trailer combination."
Dustin Ward is offline   Reply With Quote
