Old 09-12-2018, 03:29 PM   #1
Lyn Smith
Liked 979 Times in 197 Posts
Default Re: WCFB carb problem. Oil pressure ?
For sure going to bump up f pressure.Only has 6.5 now.Had another racer tell me if I want to richen the wcfb up ,just bump up the fuel pressure.Will keep you all informed.Thanks for all the info.Lyn
Old 09-12-2018, 03:56 PM   #2
FED 387
Liked 333 Times in 180 Posts
U might also want to check float level and make sure that the float is centered in the float bowl not touching the sides of the bowl at all. They were known to do that as well
