Old 09-15-2018, 12:33 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: WCFB carb problem. Oil pressure ?
Pretty cool. Lyn. You're right about the pump not being mounted above the tank outlet.
For sure. Electric pumps don't suck very well. You should have a full stream of fuel run out the fuel line on the inlet side of the pump if you pull it off the pump. At the back of the car, near the tank's sump. Vehicle acceloration should force fuel to the pump. The pump should not have to try to suck fuel against it.
Ed Wright 4156 SS/JA
